用STM32L053做矩阵键盘的代码,为什么IO口读不出数据啊
贫道5 提问时间:2018-3-17 09:29 /
麻烦各位帮忙看看
#include "KEY.h"
#define KEY_PIN_1            GPIO_PIN_0
#define KEY_PIN_2            GPIO_PIN_1
#define KEY_PIN_3            GPIO_PIN_2
#define KEY_PIN_4            GPIO_PIN_3
#define KEY_PIN_5            GPIO_PIN_4
#define KEY_PIN_6            GPIO_PIN_5
#define KEY_PIN_7            GPIO_PIN_6
#define KEY_PIN_8            GPIO_PIN_7
#define KEY_PIN_ALL         KEY_PIN_1|KEY_PIN_2|KEY_PIN_3|KEY_PIN_4|KEY_PIN_5|KEY_PIN_6|KEY_PIN_7|KEY_PIN_8
#define KEY_PORT             GPIOB
void GPIO_Init(void)
  GPIO_InitTypeDef GPIO_InitStruct;
  __HAL_RCC_GPIOB_CLK_ENABLE();
        __HAL_RCC_GPIOA_CLK_ENABLE();
        //__HAL_RCC_GPIOH_CLK_ENABLE();
  GPIO_InitStruct.Pin = KEY_PIN_1|KEY_PIN_2|KEY_PIN_3|KEY_PIN_4;
  GPIO_InitStruct.Mode = GPIO_MODE_OUTPUT_PP;
  GPIO_InitStruct.Pull = GPIO_NOPULL;
  GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_HIGH;
        HAL_GPIO_Init(KEY_PORT, &GPIO_InitStruct);
        GPIO_InitStruct.Pin = GPIO_PIN_5;
        HAL_GPIO_Init(GPIOA, &GPIO_InitStruct);
        GPIO_InitStruct.Pin = KEY_PIN_5|KEY_PIN_6|KEY_PIN_7|KEY_PIN_8;
  GPIO_InitStruct.Mode = GPIO_MODE_INPUT;
  GPIO_InitStruct.Pull = GPIO_PULLDOWN;
  //GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_HIGH;
unsigned char HL_Scan(void)
        unsigned char KeyVal=0;
        unsigned key=0;
        //unsigned int WriteVal=0;
        if(key==0)
                HAL_GPIO_WritePin(KEY_PORT,KEY_PIN_1|KEY_PIN_2|KEY_PIN_3|KEY_PIN_4,GPIO_PIN_SET);
                if(HAL_GPIO_ReadPin(KEY_PORT,KEY_PIN_5|KEY_PIN_6|KEY_PIN_7|KEY_PIN_8)==0)
                        key=0;
                        return 0;
                else
                        HAL_Delay(5);
                                key=0;
                                return 0;
                        else
                                key=1;
        if(key==1)
                HAL_GPIO_WritePin(KEY_PORT,KEY_PIN_1,GPIO_PIN_SET);
                HAL_GPIO_WritePin(KEY_PORT,KEY_PIN_2|KEY_PIN_3|KEY_PIN_4,GPIO_PIN_RESET);
                switch(HAL_GPIO_ReadPin(KEY_PORT,KEY_PIN_5|KEY_PIN_6|KEY_PIN_7|KEY_PIN_8)&0xf0)
                        case 0x10: KeyVal=15;        break;
                        case 0x20: KeyVal=11;        break;
                        case 0x40: KeyVal=7;        break;
                        case 0x80: KeyVal=3;        break;
                HAL_GPIO_WritePin(KEY_PORT,KEY_PIN_2,GPIO_PIN_SET);
                HAL_GPIO_WritePin(KEY_PORT,KEY_PIN_1|KEY_PIN_3|KEY_PIN_4,GPIO_PIN_RESET);
                        case 0x10: KeyVal=14;        break;
                        case 0x20: KeyVal=10;        break;
                        case 0x40: KeyVal=6;        break;
                        case 0x80: KeyVal=2;        break;
                HAL_GPIO_WritePin(KEY_PORT,KEY_PIN_3,GPIO_PIN_SET);
                HAL_GPIO_WritePin(KEY_PORT,KEY_PIN_1|KEY_PIN_2|KEY_PIN_4,GPIO_PIN_RESET);
                        case 0x10: KeyVal=13;        break;
                        case 0x20: KeyVal=9;        break;
                        case 0x40: KeyVal=5;        break;
                        case 0x80: KeyVal=1;        break;
                HAL_GPIO_WritePin(KEY_PORT,KEY_PIN_4,GPIO_PIN_SET);
                HAL_GPIO_WritePin(KEY_PORT,KEY_PIN_1|KEY_PIN_2|KEY_PIN_3,GPIO_PIN_RESET);
                        case 0x10: KeyVal=12;        break;
                        case 0x20: KeyVal=8;        break;
                        case 0x40: KeyVal=4;        break;
                        case 0x80: KeyVal=0;        break;
                key=0;
        return KeyVal;
点评
先把前一个帖子的情况总结一下  发表于 2018-3-20 09:36
赞 收藏 评论13 发布时间:2018-3-17 09:29
13个回答
七哥 回答时间:2018-3-17 22:11:16
先把前一个帖子的情况总结一下。
琦子 回答时间:2018-3-17 09:33:33
楼主 io口模式是不是应该设置为上拉啊,还有就是您那个外部电路上有上拉电阻吗
MrJiu 回答时间:2018-3-17 09:56:09
读不出数据啥意思?是数据出错,还是数据随机变化?
贫道5 回答时间:2018-3-17 10:10:58
bargagebaobei 发表于 2018-3-17 09:33
楼主 io口模式是不是应该设置为上拉啊,还有就是您那个外部电路上有上拉电阻吗 ...
你说的是输入改成上拉,还是输出改成上拉?外部没有上拉电阻
贫道5 回答时间:2018-3-17 10:12:28
我用万用表测管脚的电压是正确的,可结果读取管脚高低电平的时候就是进不了swicth语句。。。
贫道5 回答时间:2018-3-17 10:13:29
是不是switch(HAL_GPIO_ReadPin(KEY_PORT,KEY_PIN_5|KEY_PIN_6|KEY_PIN_7|KEY_PIN_8)&0xf0)我这句代码出问题了
琦子 回答时间:2018-3-17 10:28:26
输出的引脚啊  应该是上拉啊
琦子 回答时间:2018-3-17 10:30:22
另外我理解输入引脚应该是加一个电阻接地 然后键盘按下之后就接到了高电平 这样输入引脚就应该检测到高电平的输入
jianzhirao 回答时间:2018-3-17 13:39:19
感谢大佬
x5y4z3 回答时间:2018-3-17 16:25:01
藉由此帖亦受益良多。
feixiang20 回答时间:2018-3-17 22:18:15
是不是循环有问题啊,一般参数循环错误也会读不出
埃斯提爱慕 回答时间:2018-3-19 18:23:05
