请问JlinkV8/V9,能支STM32L0XX系列芯片吗?
scanli 提问时间:2018-3-19 12:47 /
请问JlinkV8/V9,能支STM32L0XX系列芯片吗?目前试了一下,JlinkV8不支持。
赞 收藏 评论6 发布时间:2018-3-19 12:47
6个回答
maxtch 回答时间:2018-3-19 13:21:41
v9 可以支持。你需要升级电脑上的 J-Link 驱动到最新才能用呢。
琦子 回答时间:2018-3-19 14:42:11
V8不支持,V9支持 升级驱动吧
maxtch 回答时间:2018-3-19 18:06:34
J-Link v8 升级驱动和固件到最新版本(2014 年 11 月 28 日固件,驱动版本 6.30g)是可以链接 STM32L0 的。以下是刷了我的和谐版固件的 v8 在 UNIX 下连接 STM32L021D4P6 并抹片的记录。
  1. $ JLinkExe
  2. SEGGER J-Link Commander V6.30g (Compiled Mar 12 2018 17:24:16)
  3. DLL version V6.30g, compiled Mar 12 2018 17:24:07
  4. Connecting to J-Link via USB...O.K.
  5. Firmware: J-Link ARM V8 compiled Nov 28 2014 13:44:46
  6. Hardware version: V8.00
  7. S/N: 40542521
  8. License(s): RDI,FlashDL,FlashBP,JFlash,GDB
  9. VTref = 2.808V
  10. J-Link>connect
  11. Please specify device / core. <Default>: STM32F030C8
  12. Type '?' for selection dialog
  13. Device>stm32l021d4
  14. Please specify target interface:
  15.   J) JTAG (Default)
  16.   S) SWD
  17. TIF>s
  18. Specify target interface speed [kHz]. <Default>: 4000 kHz
  19. Speed>
  20. Device "STM32L021D4" selected.
  21. Connecting to target via SWD
  22. Found SW-DP with ID 0x0BC11477
  23. STM32 (connect): Can not attach to CPU. Trying connect under reset.
  24. Found SW-DP with ID 0x0BC11477
  25. Found SW-DP with ID 0x0BC11477
  26. Scanning AP map to find all available APs
  27. AP[1]: Stopped AP scan as end of AP map has been reached
  28. AP[0]: AHB-AP (IDR: 0x04770031)
  29. Iterating through AP map to find AHB-AP to use
  30. AP[0]: Core found
  31. AP[0]: AHB-AP ROM base: 0xF0000000
  32. CPUID register: 0x410CC601. Implementer code: 0x41 (ARM)
  33. Found Cortex-M0 r0p1, Little endian.
  34. FPUnit: 4 code (BP) slots and 0 literal slots
  35. CoreSight components:
  36. ROMTbl[0] @ F0000000
  37. ROMTbl[0][0]: E00FF000, CID: B105100D, PID: 000BB4C0 ROM Table
  38. ROMTbl[1] @ E00FF000
  39. ROMTbl[1][0]: E000E000, CID: B105E00D, PID: 000BB008 SCS
  40. ROMTbl[1][1]: E0001000, CID: B105E00D, PID: 000BB00A DWT
  41. ROMTbl[1][2]: E0002000, CID: B105E00D, PID: 000BB00B FPB
  42. Reset: Halt core after reset via DEMCR.VC_CORERESET.
  43. Reset: Reset device via AIRCR.SYSRESETREQ.
  44. Cortex-M0 identified.
  45. J-Link>erase
  46. Erasing device (STM32L021D4)...
  47. Comparing flash   [100%] Done.
  48. Erasing flash     [100%] Done.
  49. Verifying flash   [100%] Done.
  50. J-Link: Flash download: Total time needed: 0.472s (Prepare: 0.027s, Compare: 0.000s, Erase: 0.440s, Program: 0.000s, Verify: 0.000s, Restore: 0.004s)
  51. Erasing done.
  52. J-Link>
zhao.zhao 回答时间:2018-3-20 09:04:40
Jink-V9肯定支持
参与人数 1蝴蝶豆 +1 收起 理由
zero99 + 1
Inc_brza 回答时间:2018-3-20 09:12:37
V8不行是因为驱动太旧,大概这是V8山寨不敢升级的原因吧,需要手动升级。
V9现在可以直接升不会掉固件,所以驱动可以更到最新版本没问题。
maxtch 回答时间:2018-3-20 14:02:58
V9现在可以直接升不会掉固件,所 ...
我有做一个 v8 和谐版固件,可以大胆升级,升级后可以正常连接 L0 系列。
