STM32_深圳峰会_黑客松,奖品开箱
ghost110 发布时间:2021-5-12 10:19
感谢管理“Seven”,因为工作原因不能实地参加STM32的深圳会议,在seven管理的热心组织下,通过线上直播让我了解了这一次的技术盛况,从开始的技术讲解到后期的竞赛直播,各个阶段都充分体现了专业性、素养性。不但使我学习了知识,同时也更好的了解了STM32的相关技术和使用场景,对我个人是一个很大的提升,在此对ST公司和seven管理再次表示感谢。
2 T3 P- m* Y+ w, h( G在黑客松的比赛中通过各个参赛队伍的作品,看到了不同的创意,产品技术是固定的,关键看人怎么使用。同样的平台,不同的思考方向,差异化的使用方法,打造出不同的产品方案。十分棒。在观看的过程中有幸获得抽奖奖品“STM32G474”,目前已经收到。谢谢。  Q( F! c* Y( j& Y! ~4 h5 E* J; `9 T
希望以后的活动更加丰富,开发出更多的产品。
% t  [. F: b: c3 a# Q  w+ Y+ N. j2 L& |3 |
/ ?) o3 {& v  L, `" U
7 m( l5 ]2 F1 ?. ~
& f' Z% z6 L  d/ X! j4 _描述8 ^/ L2 R1 Y$ d9 D
The STM32G474xB/xC/xE devices are based on the high-performance Arm® Cortex®-M4 32-bit RISC core. They operate at a frequency of up to 170 MHz. The Cortex-M4 core features a single-precision floating-point unit (FPU), which supports all the Arm single-precision data-processing instructions and all the data types. It also implements a full set of DSP (digital signal processing) instructions and a memory protection unit (MPU) which enhances the application’s security.
& A5 K' ?4 z" G5 ^( LThese devices embed high-speed memories (512 Kbytes of Flash memory, and 128 Kbytes of SRAM), a flexible external memory controller (FSMC) for static memories (for devices with packages of 100 pins and more), a Quad SPI Flash memory interface, and an extensive range of enhanced I/Os and peripherals connected to two APB buses, two AHB buses and a 32-bit multi-AHB bus matrix.
# y" k+ I& c" P1 \& d/ TThe devices also embed several protection mechanisms for embedded Flash memory and SRAM: readout protection, write protection, securable memory area and proprietary code readout protection.3 Q# y* g  r$ P% }' q" y
The devices embed peripherals allowing mathematical/arithmetic function acceleration (CORDIC for trigonometric functions and FMAC unit for filter functions).1 g$ n# t# |  N: a
They offer five fast 12-bit ADCs (5 Msps), seven comparators, six operational amplifiers, seven DAC channels (3 external and 4 internal), an internal voltage reference buffer, a low-power RTC, two general-purpose 32-bit timers, three 16-bit PWM timers dedicated to motor control, seven general-purpose 16-bit timers, and one 16-bit low-power timer, and high resolution timer with 184 ps resolution.+ @. s% s) ~4 g9 A7 Y, l
They also feature standard and advanced communication interfaces such as:# d4 t: d2 h7 n3 t) s. e4 [' z4 J( |
所有功能
& e$ r# [  H& [# J  UCore: Arm® 32-bit Cortex®-M4 CPU with FPU, Adaptive real-time accelerator (ART Accelerator) allowing 0-wait-state execution from Flash memory, frequency up to 170 MHz with 213 DMIPS, MPU, DSP instructions3 f; O3 u; |0 L- s& U( O3 U$ K
Operating conditions:: U" {7 r' n" v# Y- R  E
VDD, VDDA voltage range: 1.71 V to 3.6 V" I2 S! q/ n9 ?+ Q5 Y" P* O# r
Mathematical hardware accelerators. Q% N* L# k9 ^- y: L
CORDIC for trigonometric functions acceleration* c2 a( i; |+ }3 \) U2 g
FMAC: filter mathematical accelerator
7 x. v4 S% C. Z, y: K3 {Memories
  C5 l% {! H. A512 Kbytes of Flash memory with ECC support, two banks read-while-write, proprietary code readout protection (PCROP), securable memory area, 1 Kbyte OTP
: B1 S( b! {8 r; k96 Kbytes of SRAM, with hardware parity check implemented on the first 32 Kbytes: ?  J& @2 D+ d& \$ ^& _! a" |, |! K! L
Routine booster: 32 Kbytes of SRAM on instruction and data bus, with hardware parity check (CCM SRAM)$ h1 W$ l0 W& s5 l: S: [
External memory interface for static memories FSMC supporting SRAM, PSRAM, NOR and NAND memories- Y5 h7 U$ Q$ g8 k+ [
Quad-SPI memory interface5 r" O' d. k+ w& _; Q
Reset and supply management$ n+ k& R  R% J! C2 d
Power-on/power-down reset (POR/PDR/BOR)
# U1 _" o: y. |Programmable voltage detector (PVD)' h0 z- L& a, l0 K
Low-power modes: sleep, stop, standby and shutdown
6 @" l! |- [/ ?+ zVBAT supply for RTC and backup registers; J. j. c. ]4 f, j" W0 M3 c, u" F
Clock management
8 J" T4 e8 y- H0 F# V$ P: C" B  }! d/ h3 s4 to 48 MHz crystal oscillator3 {9 Z. K6 g, f$ L  h
32 kHz oscillator with calibration
+ M+ x# x7 i8 y4 ?  S) MInternal 16 MHz RC with PLL option (± 1%)
  \+ Q: `! X  E$ ^, E' ^Internal 32 kHz RC oscillator (± 5%)
) t% q; |7 J) VUp to 107 fast I/Os6 f. a: ]: K% l1 b
All mappable on external interrupt vectors8 x5 j% D) Z4 [* t
Several I/Os with 5 V tolerant capability
; j. M, Q# P$ c) |Interconnect matrix3 M, ]8 K: X! L/ R* J
16-channel DMA controller
* |2 B+ }1 F/ a6 m+ b5 x 12-bit ADCs 0.25 µs, up to 42 channels. Resolution up to 16-bit with hardware oversampling, 0 to 3.6 V conversion range. ?2 ]9 {, ~! h" t- l
7 x 12-bit DAC channels
7 t4 a5 _7 W4 {7 H! T3 x buffered external channels 1 MSPS
; t# v$ X$ N3 n- g5 w4 x unbuffered internal channels 15 MSPS: h2 f7 S0 F' v) B
7 x ultra-fast rail-to-rail analog comparators9 D% W- S% u' S( H, e/ X
6 x operational amplifiers that can be used in PGA mode, all terminals accessible; s- q1 b. [* w, a3 Z  Q- g
Internal voltage reference buffer (VREFBUF) supporting three output voltages (2.048 V, 2.5 V, 2.95 V)! R! m3 o2 w! T7 G) Q. p
17 timers:5 C( x& q9 `4 M, K3 B/ a$ V/ h
HRTIM (Hi-Resolution and complex waveform builder): 6 x16-bit counters, 184 ps resolution, 12 PWM
+ q* k; r/ |8 i) @6 V: }0 E' m! h: u2 x 32-bit timer and 2 x 16-bit timers with up to four IC/OC/PWM or pulse counter and quadrature (incremental) encoder input
8 m" E* W! ?% g1 r3 e3 x 16-bit 8-channel advanced motor control timers, with up to 8 x PWM channels, dead time generation and emergency stop  T1 J2 Y6 s. m6 I
1 x 16-bit timer with 2 x IC/OCs, one OCN/PWM, dead time generation and emergency stop7 O. E. z9 P& g" u0 r% d
2 x 16-bit timers with IC/OC/OCN/PWM, dead time generation and emergency stop
* w! B9 B# j) ^0 r2 x watchdog timers (independent, window)! a1 @: z3 E9 B5 w1 i  n
1 x SysTick timer: 24-bit downcounter
# ^5 R) e0 [/ S& {: r2 x 16-bit basic timers4 I" S1 k# t7 J* u0 ?
1 x low-power timer
1 ~6 V1 t, S5 g& RCalendar RTC with alarm, periodic wakeup from stop/standby; m: L9 {" _* k* A8 z( k
Communication interfaces& K% b. |( {2 |1 i2 |
3 x FDCAN controller supporting flexible data rate
1 `2 ?3 ?% d! D1 r/ i" t+ H4 x I2C Fast mode plus (1 Mbit/s) with 20 mA current sink, SMBus/PMBus, wakeup from stop' x8 r. C0 N: @
5 x USART/UARTs (ISO 7816 interface, LIN, IrDA, modem control)+ v, z: j% J! v& d5 r
1 x LPUART
: }  X8 K" n  s4 x SPIs, 4 to 16 programmable bit frames, 2 x with multiplexed half duplex I2S interface
/ I, O9 r% a0 D/ ~% J# F1 x SAI (serial audio interface)$ r8 P! B8 ^, \; z% p! N  t: c$ T
USB 2.0 full-speed interface with LPM and BCD support" r5 P1 N9 t8 @* N7 @- P! P; N3 v4 _
IRTIM (infrared interface)9 v0 n3 I9 L) ^# w0 R
USB Type-C™ /USB power delivery controller (UCPD)" K3 L6 p& U$ _$ m' v; Y) w
True random number generator (RNG)- _1 M1 a( l  n2 Y
CRC calculation unit, 96-bit unique ID: b  j% j* T6 m& K1 _9 ~
Development support: serial wire debug (SWD), JTAG, Embedded Trace Macrocell™
+ m" i/ c. a3 E7 }+ B" I8 H
赞 1 收藏 评论0 发布时间:2021-5-12 10:19
