01. ADC概述* n( Y; A, w* {/ J; t' p; g
STM32F4xx 系列一般都有 3 个 ADC,这些 ADC 可以独立使用,也可以使用双重/三重模式(提高采样率)。STM32F4 的 ADC 是 12 位逐次逼近型的模拟数字转换器。它有 19 个通道,可测量 16 个外部源、2 个内部源和 Vbat 通道的信号。这些通道的 A/D 转换可以单次、连续、扫描或间断模式执行。ADC 的结果可以左对齐或右对齐方式存储在 16 位数据寄存器中。 模拟看门狗特性允许应用程序检测输入电压是否超出用户定义的高/低阀值。
9 v) S- r; a6 Q/ I0 C' i, s! l
- T5 a s) k2 J. Z相关文件为 stm32f4xx_adc.h和 stm32f4xx_adc.c。 E8 S# e7 v% d0 I8 h7 Z
5 W. y" ]0 }2 n. o: X' V02. 相关类型: q% f1 I5 M: y# {$ y
- /** * b0 b$ A7 c+ m! q
- * @brief ADC Init structure definition 2 D2 n: I1 B( t! Z6 \2 @% N
- */ * y: r# i/ Y7 w! w, F! H& m
- typedef struct
! H* M! K z( f, [9 y - {
2 ~: o V6 ~, Q# r! J8 N! O - uint32_t ADC_Resolution; /*!< Configures the ADC resolution dual mode.
% b, q) B3 ]+ w& ~: h. ]: R! ^) X - This parameter can be a value of @ref ADC_resolution */ 4 `8 U& X/ j2 ?
- FunctionalState ADC_ScanConvMode; /*!< Specifies whether the conversion
- d2 {! }4 {( R! D" j1 g+ s - is performed in Scan (multichannels)
2 D5 v, h! J: F$ a V - or Single (one channel) mode.
3 Q: R$ [$ e6 B9 w s - This parameter can be set to ENABLE or DISABLE */
# K' a |3 ~5 W - FunctionalState ADC_ContinuousConvMode; /*!< Specifies whether the conversion : ?* }/ [+ y" x& f# h6 g3 Q
- is performed in Continuous or Single mode.4 S$ d; m$ P6 ~1 A$ ~
- This parameter can be set to ENABLE or DISABLE. */
! T& k4 K& ?) Y - uint32_t ADC_ExternalTrigConvEdge; /*!< Select the external trigger edge and
6 Y- {: U8 R+ f7 G$ c7 u) q- N5 I - enable the trigger of a regular group.
5 r0 D8 K+ j% [9 w; J8 K - This parameter can be a value of ' v! K2 F/ K( G/ ~0 w; Z- E7 e
- @ref ADC_external_trigger_edge_for_regular_channels_conversion */, g3 p& J. u* Z2 M, ]1 {
- uint32_t ADC_ExternalTrigConv; /*!< Select the external event used to trigger
- n" I4 D2 H% Q" R! k: N - the start of conversion of a regular group.& G: S1 t! p1 b5 |
- This parameter can be a value of % x# N a+ I! A+ l- k' N A+ A
- @ref ADC_extrenal_trigger_sources_for_regular_channels_conversion */
& l3 y, x) q; |. X H - uint32_t ADC_DataAlign; /*!< Specifies whether the ADC data alignment
, k! v* S8 i$ P - is left or right. This parameter can be - A) T8 s5 K% H2 Q4 y
- a value of @ref ADC_data_align */
5 g/ o7 D) j( V4 g - uint8_t ADC_NbrOfConversion; /*!< Specifies the number of ADC conversions
9 q7 {+ {$ C* p: x- E6 u - that will be done using the sequencer for
1 f4 q4 B9 J4 z5 B - regular channel group.
, U$ n: y N, C( Q ? - This parameter must range from 1 to 16. */
* A7 Q9 ]* n% j K( o/ @. Y) h/ M - }ADC_InitTypeDef;- P2 a3 I; I( B4 p0 l4 V* p* e$ p6 Z7 D
- ) J; J( U# u: b) a- t( u
: f2 ~8 \+ k$ M+ U8 E' V6 ]3 | - * @brief ADC Common Init structure definition 7 u; M- N2 C+ H- p
- */ $ f E2 u9 `, S* }; W
- typedef struct u" H% W0 l+ w o- N; D- B, R. C5 R
- {0 I7 {+ F# ^* e2 W0 { T
- uint32_t ADC_Mode; /*!< Configures the ADC to operate in
- ^+ U z5 y. G% X3 {5 F - independent or multi mode. * |) t6 L1 V9 C9 E0 ], `
- This parameter can be a value of @ref ADC_Common_mode */ + k8 i; W( R z) K
- uint32_t ADC_Prescaler; /*!< Select the frequency of the clock
+ ?! _4 `) H! K$ ~0 e) \% A - to the ADC. The clock is common for all the ADCs.
/ a4 z$ I/ {: t8 P, o- c3 M6 q4 t - This parameter can be a value of @ref ADC_Prescaler */. ]7 z8 y+ a4 O; w$ O* o
- uint32_t ADC_DMAAccessMode; /*!< Configures the Direct memory access
1 }- Z1 Q, V8 g' g/ } - mode for multi ADC mode.( O1 M) V0 I' F+ u% A
+ {! H( n: x# s% H* M2 D- R0 c - @ref ADC_Direct_memory_access_mode_for_multi_mode */5 D+ ? W' P8 k( Z
- uint32_t ADC_TwoSamplingDelay; /*!< Configures the Delay between 2 sampling phases.* @- s/ ?: S9 G9 d7 S# }# U
- This parameter can be a value of . a) B3 g9 B3 p3 k6 o8 v& d
- @ref ADC_delay_between_2_sampling_phases */2 z4 b( k. W' m( R1 u4 ~ Z
- - F" G( I% y# ^9 K' q9 I
- }ADC_CommonInitTypeDef;0 C6 X( I& j/ K% X& ~
0 W1 W4 S0 G% w5 ?" [- ; X6 h+ [" \+ `
- /* Exported constants --------------------------------------------------------*/7 J4 r v3 W8 x2 e" t
- 3 s3 r/ a G4 J# Q/ Y
- /** @defgroup ADC_Exported_Constants
, C+ ?' @! t/ M+ l% B - * @{
8 q# k) [# a+ ^+ z - */
3 m2 E" X" m6 P - #define IS_ADC_ALL_PERIPH(PERIPH) (((PERIPH) == ADC1) || \
+ X9 Z$ Y2 B$ Y% G6 S1 q- ~+ @+ q - ((PERIPH) == ADC2) || \$ a% I. C7 f7 ~2 |0 v) t0 G
- ((PERIPH) == ADC3)) - y+ Y" r2 t' }* y- u1 a8 G! @
- # l' J: l6 |! _, s
- /** @defgroup ADC_Common_mode 0 `- X [* q7 ~
- * @{+ k3 |8 m% N6 B! W% o% j
* w9 v; x& L% W+ a8 T3 x A - #define ADC_Mode_Independent ((uint32_t)0x00000000)
* l, K9 e7 G" ^6 N" { - #define ADC_DualMode_RegSimult_InjecSimult ((uint32_t)0x00000001)4 }) d0 n3 B( {, N2 x' Q7 t1 A% n
- #define ADC_DualMode_RegSimult_AlterTrig ((uint32_t)0x00000002)
& \# o, H* V. [7 S3 w/ } - #define ADC_DualMode_InjecSimult ((uint32_t)0x00000005)
# u. H" q8 h1 S: a ~/ T7 I$ p - #define ADC_DualMode_RegSimult ((uint32_t)0x00000006)
' ^# P1 s1 K4 A2 q* }" ^( J$ L - #define ADC_DualMode_Interl ((uint32_t)0x00000007)
$ b7 n: j" b6 z - #define ADC_DualMode_AlterTrig ((uint32_t)0x00000009)# U* a2 |) h( u+ l& q2 Q T/ G
- #define ADC_TripleMode_RegSimult_InjecSimult ((uint32_t)0x00000011)5 R @: E: g' |* |" o6 i! \
- #define ADC_TripleMode_RegSimult_AlterTrig ((uint32_t)0x00000012)
$ Y& n: K, }! ~2 j9 s2 a5 N - #define ADC_TripleMode_InjecSimult ((uint32_t)0x00000015)' \/ r g0 { O0 ~2 u
- #define ADC_TripleMode_RegSimult ((uint32_t)0x00000016)
/ Q5 P4 _$ {. o8 U% ` - #define ADC_TripleMode_Interl ((uint32_t)0x00000017)2 b& t- T* P3 h1 H4 b
- #define ADC_TripleMode_AlterTrig ((uint32_t)0x00000019)
# K. H- V/ H: P; U& _ - #define IS_ADC_MODE(MODE) (((MODE) == ADC_Mode_Independent) || \1 w% S: o. A5 a$ c; r% t
- ((MODE) == ADC_DualMode_RegSimult_InjecSimult) || \
! x% D0 N' v t ^/ C - ((MODE) == ADC_DualMode_RegSimult_AlterTrig) || \
" O4 [5 k" i) B2 W% F- n - ((MODE) == ADC_DualMode_InjecSimult) || \
' e; A4 Q. g" e- y' m - ((MODE) == ADC_DualMode_RegSimult) || \
+ e! [/ U5 q: m9 J1 N& | - ((MODE) == ADC_DualMode_Interl) || \
' k4 Y' F, T( |0 y' M% y d& s - ((MODE) == ADC_DualMode_AlterTrig) || \' c! C5 T# [4 G/ f
- ((MODE) == ADC_TripleMode_RegSimult_InjecSimult) || \' m3 q9 c3 V: B, N: d( `
- ((MODE) == ADC_TripleMode_RegSimult_AlterTrig) || \
' k- ~- A& h. d y' H6 f, C - ((MODE) == ADC_TripleMode_InjecSimult) || \# Z0 X; n1 ~% m0 I3 R+ v/ Z9 a& R
- ((MODE) == ADC_TripleMode_RegSimult) || \. X* e* S9 T& M- ?) {! ^) e3 E
- ((MODE) == ADC_TripleMode_Interl) || \0 h. d; t1 C1 N( r3 g; C$ _
- ((MODE) == ADC_TripleMode_AlterTrig))
! u, ?2 V3 Z4 e+ w. x - /**
( w- \5 M1 a" @& `; X0 m. d - * @}
8 z: ]5 Z! p! r. F - */ 1 `7 b& `* @4 }1 Y" C3 h
- / b+ n, l/ n" }9 h2 F3 H
- 5 H- q- Z4 \3 @5 Y
- /** @defgroup ADC_Prescaler
/ F; ], A, [$ W- o; |" l$ { - * @{
9 W1 I$ d; |5 |2 p' @" i* w - */
- _$ g1 \7 w$ S2 `* w" D - #define ADC_Prescaler_Div2 ((uint32_t)0x00000000)4 }( v' V c t* k0 M$ N5 V& h' w6 o+ g/ s
- #define ADC_Prescaler_Div4 ((uint32_t)0x00010000). `- ]7 Q7 n% z) s8 i: b( z& q
- #define ADC_Prescaler_Div6 ((uint32_t)0x00020000)0 {! Z) m1 u9 I8 H( h8 _4 P9 [
- #define ADC_Prescaler_Div8 ((uint32_t)0x00030000)- J R# X9 v2 E$ F5 I% s
- #define IS_ADC_PRESCALER(PRESCALER) (((PRESCALER) == ADC_Prescaler_Div2) || \) ]( A: X5 G3 E2 A8 u
- ((PRESCALER) == ADC_Prescaler_Div4) || \6 _8 e+ l; n! E+ ?+ h
- ((PRESCALER) == ADC_Prescaler_Div6) || \' C# P& s) g" }. m$ _6 w# X
- ((PRESCALER) == ADC_Prescaler_Div8))
" d6 q! r& a$ m) [) L( P" X - /**
% b( V$ D3 @1 a& ~7 {% N - * @}
$ h: v0 {2 h& N5 V9 W4 o - */ $ @5 z" E; @6 c5 F$ g
- 0 [8 v; H2 b6 ]; n
- 5 F- I5 H! b' V, p5 l% P4 Z
- /** @defgroup ADC_Direct_memory_access_mode_for_multi_mode
; L' P% v( @1 n I7 q* X2 I - * @{
# a+ ?( x; h& r3 Z2 x - */ $ x% e0 l9 ^0 k
- #define ADC_DMAAccessMode_Disabled ((uint32_t)0x00000000) /* DMA mode disabled */
7 y0 G% i# ~- | - #define ADC_DMAAccessMode_1 ((uint32_t)0x00004000) /* DMA mode 1 enabled (2 / 3 half-words one by one - 1 then 2 then 3)*/6 P5 J8 o# P1 \! j% X& e# z. W
- #define ADC_DMAAccessMode_2 ((uint32_t)0x00008000) /* DMA mode 2 enabled (2 / 3 half-words by pairs - 2&1 then 1&3 then 3&2)*/
+ X1 W" C2 p, }% ^6 X2 ]8 K - #define ADC_DMAAccessMode_3 ((uint32_t)0x0000C000) /* DMA mode 3 enabled (2 / 3 bytes by pairs - 2&1 then 1&3 then 3&2) */
! K @% j3 Y& c/ T7 A - #define IS_ADC_DMA_ACCESS_MODE(MODE) (((MODE) == ADC_DMAAccessMode_Disabled) || \5 }: w4 a- j! j* {' V
- ((MODE) == ADC_DMAAccessMode_1) || \
9 S1 ]# m5 Z( \' f8 u3 B - ((MODE) == ADC_DMAAccessMode_2) || \
$ c+ @) N7 q$ ?, s& h( y - ((MODE) == ADC_DMAAccessMode_3))
4 o3 M% e4 }) T: l/ c/ o - % w4 |/ k K: ^8 g4 o7 A) g# Y
- /**: o* K9 y% a5 \5 ]9 d7 d
- * @}% S- M6 r: |( Y; p/ a* V0 K
+ J8 Z) v( P2 D i6 S \ - 7 ]$ d6 t. C; @+ j0 y2 o4 N3 {
1 m% ~! N- m% u, e* _- /** @defgroup ADC_delay_between_2_sampling_phases % `" T/ A4 \" ?2 I1 p! z( Z
- * @{1 B- k, X$ R+ R5 _
6 I$ }2 m, w# @) n - #define ADC_TwoSamplingDelay_5Cycles ((uint32_t)0x00000000)9 ]6 i J! u1 y' n. y) q
- #define ADC_TwoSamplingDelay_6Cycles ((uint32_t)0x00000100)
& C N P0 N# ]( U" Y - #define ADC_TwoSamplingDelay_7Cycles ((uint32_t)0x00000200)7 U. S* w1 m; ^6 w) |8 S
- #define ADC_TwoSamplingDelay_8Cycles ((uint32_t)0x00000300)
% p' r7 j$ K2 ?* [$ Q( g( P - #define ADC_TwoSamplingDelay_9Cycles ((uint32_t)0x00000400)
- |; t$ P) e8 A$ N' V" t - #define ADC_TwoSamplingDelay_10Cycles ((uint32_t)0x00000500): n8 u Y6 [2 V5 p( z
- #define ADC_TwoSamplingDelay_11Cycles ((uint32_t)0x00000600)" a( \' b* g4 B- E; {) }# b' |/ w+ ~
- #define ADC_TwoSamplingDelay_12Cycles ((uint32_t)0x00000700)& Z% u/ @1 h/ H& o- L# U. J
- #define ADC_TwoSamplingDelay_13Cycles ((uint32_t)0x00000800)
) o N) D0 w+ q. @* w3 k - #define ADC_TwoSamplingDelay_14Cycles ((uint32_t)0x00000900)7 i3 b( T( h& C: ~: K0 t
- #define ADC_TwoSamplingDelay_15Cycles ((uint32_t)0x00000A00): K+ }; U# F3 H
- #define ADC_TwoSamplingDelay_16Cycles ((uint32_t)0x00000B00)
" u( _- G0 O S* Z4 N - #define ADC_TwoSamplingDelay_17Cycles ((uint32_t)0x00000C00)- K8 f5 X6 r/ m2 I- b% J
- #define ADC_TwoSamplingDelay_18Cycles ((uint32_t)0x00000D00)2 ~! j2 @; r+ s/ r- I- ^. i
- #define ADC_TwoSamplingDelay_19Cycles ((uint32_t)0x00000E00)
; [9 h3 }- [1 o% b4 y7 b! u - #define ADC_TwoSamplingDelay_20Cycles ((uint32_t)0x00000F00)
# h) m/ ^& L' B6 F0 n1 A - #define IS_ADC_SAMPLING_DELAY(DELAY) (((DELAY) == ADC_TwoSamplingDelay_5Cycles) || \4 T% c4 s! @+ O A5 u. O9 p# g
- ((DELAY) == ADC_TwoSamplingDelay_6Cycles) || \
7 V2 A0 ]2 a8 G w - ((DELAY) == ADC_TwoSamplingDelay_7Cycles) || \
& y5 k& t* d; w: J, ?( b - ((DELAY) == ADC_TwoSamplingDelay_8Cycles) || \+ _# {# e, x1 l7 f ?: O; g
- ((DELAY) == ADC_TwoSamplingDelay_9Cycles) || \/ l+ y% k% M) G ?5 V
- ((DELAY) == ADC_TwoSamplingDelay_10Cycles) || \# h: }9 s) X& G% q6 G5 U( }
- ((DELAY) == ADC_TwoSamplingDelay_11Cycles) || \
, Z% e9 Q1 `; S2 W - ((DELAY) == ADC_TwoSamplingDelay_12Cycles) || \
$ Y( V5 [8 Z5 j) W - ((DELAY) == ADC_TwoSamplingDelay_13Cycles) || \# c5 T- e; ]- _3 f5 h( l; X
- ((DELAY) == ADC_TwoSamplingDelay_14Cycles) || \9 K6 F0 `9 i) L+ c4 g
- ((DELAY) == ADC_TwoSamplingDelay_15Cycles) || \( Y. O, d6 O4 F" l! G! y6 y0 c
- ((DELAY) == ADC_TwoSamplingDelay_16Cycles) || \0 p8 V" r- l/ v4 d) m/ F7 v' l- Q
- ((DELAY) == ADC_TwoSamplingDelay_17Cycles) || \
N3 E6 n1 [7 S- j/ \& p/ l - ((DELAY) == ADC_TwoSamplingDelay_18Cycles) || \
7 [' t- |4 ^7 o - ((DELAY) == ADC_TwoSamplingDelay_19Cycles) || \" A2 [& F5 D& {" V9 @
- ((DELAY) == ADC_TwoSamplingDelay_20Cycles))7 E3 F4 H w8 f7 v
6 [( F* ]: r1 A& G; C6 I- /**, }% |- B W0 T& _
- * @}; @' T0 t; d9 a, {0 m
- */ ( R$ L5 p3 W* [! _" \& B _
- 8 l4 E9 b: O( m
$ L. ~! g/ x* d+ r- /** @defgroup ADC_resolution & f8 F: R- K# y' i1 z6 C% Y' M- J
) ]2 ~' H7 M/ b2 Q# _- O9 D - */ # H: E# @/ }% k+ O' M" T0 |
- #define ADC_Resolution_12b ((uint32_t)0x00000000)' d2 G( U$ T' F2 A e8 {
- #define ADC_Resolution_10b ((uint32_t)0x01000000)" L _$ y5 P0 `* ?; H
- #define ADC_Resolution_8b ((uint32_t)0x02000000)3 H5 C+ w+ ^6 P4 A- E O
- #define ADC_Resolution_6b ((uint32_t)0x03000000)
9 G% q- F0 G; S+ [5 W, S# K - #define IS_ADC_RESOLUTION(RESOLUTION) (((RESOLUTION) == ADC_Resolution_12b) || \
, W! J" n. Z, w - ((RESOLUTION) == ADC_Resolution_10b) || \
- H) q7 d# ^/ U - ((RESOLUTION) == ADC_Resolution_8b) || \" ?. i: Z) a( w& x: x
- ((RESOLUTION) == ADC_Resolution_6b))3 z i$ E n. E5 `( o) t0 W
- 3 A0 G7 G, r( @% v' z r0 X7 l% }
- /**) O0 `2 t0 c3 {- [
/ ]9 H- @' e6 t$ }) d) l - */ 4 g( p7 i( z- d8 F3 H
" y8 ~3 V h1 D. \4 c- ( ~& ~0 u0 q8 C, p# V1 h F+ N
- /** @defgroup ADC_external_trigger_edge_for_regular_channels_conversion
. w) M/ C& L$ I O! E" _ - * @{
: k4 S7 z! W! w, H4 u- l - */ 9 D! C8 [7 c I8 d, O
- #define ADC_ExternalTrigConvEdge_None ((uint32_t)0x00000000)
, `' W$ }+ i4 `/ F, i - #define ADC_ExternalTrigConvEdge_Rising ((uint32_t)0x10000000)
5 j/ z6 \6 i9 s: I3 c% K* U - #define ADC_ExternalTrigConvEdge_Falling ((uint32_t)0x20000000)
8 l% \6 p% N/ g8 k - #define ADC_ExternalTrigConvEdge_RisingFalling ((uint32_t)0x30000000)+ @6 M% i2 ?/ B* C8 J& V' W+ }
- #define IS_ADC_EXT_TRIG_EDGE(EDGE) (((EDGE) == ADC_ExternalTrigConvEdge_None) || \
0 h$ u( M- o# A; q" ]4 ]6 E. I# E - ((EDGE) == ADC_ExternalTrigConvEdge_Rising) || \
3 T9 g3 B; |$ } - ((EDGE) == ADC_ExternalTrigConvEdge_Falling) || \( x9 b0 O: j1 P: I7 t* v! c
- ((EDGE) == ADC_ExternalTrigConvEdge_RisingFalling))$ K. s( E; l7 z- F; V, y5 i/ I
- /**4 m( @$ m' F; Q
# Z' q0 K0 U+ i7 p: H5 W - */
& I0 b. e5 W8 Z/ {- w, s - # W) R; A v- y( T( E
- 4 _4 P% p* k6 U; t
- /** @defgroup ADC_extrenal_trigger_sources_for_regular_channels_conversion
* y. z3 y; J" \, j2 Y9 z# E% C - * @{# M6 I7 P3 N6 z. @, k
- */ 0 P* ^$ N9 x+ [, A
- #define ADC_ExternalTrigConv_T1_CC1 ((uint32_t)0x00000000)* g4 H8 R; H' ` Z
- #define ADC_ExternalTrigConv_T1_CC2 ((uint32_t)0x01000000); E* ]. t# Q" o4 A# g
- #define ADC_ExternalTrigConv_T1_CC3 ((uint32_t)0x02000000)
2 A7 _! p" L4 X# B - #define ADC_ExternalTrigConv_T2_CC2 ((uint32_t)0x03000000)7 ~; {' @! l6 X! |/ p
- #define ADC_ExternalTrigConv_T2_CC3 ((uint32_t)0x04000000)6 c4 j+ X/ j; W! D" ?0 \
- #define ADC_ExternalTrigConv_T2_CC4 ((uint32_t)0x05000000)# L; \! G! h4 ]! A* c" G
- #define ADC_ExternalTrigConv_T2_TRGO ((uint32_t)0x06000000)
0 L' ?4 |4 r7 \& o$ v# ? - #define ADC_ExternalTrigConv_T3_CC1 ((uint32_t)0x07000000)
+ p; W" u. I2 N1 @6 z4 x - #define ADC_ExternalTrigConv_T3_TRGO ((uint32_t)0x08000000)
7 g" v' \1 m- }) I& ^5 W0 T - #define ADC_ExternalTrigConv_T4_CC4 ((uint32_t)0x09000000)
t; u- ~ e! W; K1 t - #define ADC_ExternalTrigConv_T5_CC1 ((uint32_t)0x0A000000)
# @. A8 r0 q( ~0 J - #define ADC_ExternalTrigConv_T5_CC2 ((uint32_t)0x0B000000): i, Q4 p2 {3 y
- #define ADC_ExternalTrigConv_T5_CC3 ((uint32_t)0x0C000000) T. }. |* X* g
- #define ADC_ExternalTrigConv_T8_CC1 ((uint32_t)0x0D000000)* ?7 r/ N3 m: x% ~& L6 {
- #define ADC_ExternalTrigConv_T8_TRGO ((uint32_t)0x0E000000)& ~; Y F6 `, g3 s8 A
- #define ADC_ExternalTrigConv_Ext_IT11 ((uint32_t)0x0F000000)
2 d- ?% [" q8 m- _ - #define IS_ADC_EXT_TRIG(REGTRIG) (((REGTRIG) == ADC_ExternalTrigConv_T1_CC1) || \/ B: }! p' S& Y
- ((REGTRIG) == ADC_ExternalTrigConv_T1_CC2) || \
1 K! ?+ @( A$ k! \ b - ((REGTRIG) == ADC_ExternalTrigConv_T1_CC3) || \
1 p' j6 [+ t1 g4 g0 h% q- J- U - ((REGTRIG) == ADC_ExternalTrigConv_T2_CC2) || \
/ l5 T/ t/ A- R4 h/ Y4 N - ((REGTRIG) == ADC_ExternalTrigConv_T2_CC3) || \2 ?4 i& {& T& |2 m
- ((REGTRIG) == ADC_ExternalTrigConv_T2_CC4) || \& m; h! q: C! v. S1 p% A C! S
- ((REGTRIG) == ADC_ExternalTrigConv_T2_TRGO) || \* w! {3 d( K: j+ B
- ((REGTRIG) == ADC_ExternalTrigConv_T3_CC1) || \
" ?' F9 P& S8 G+ W1 ?3 k* Z - ((REGTRIG) == ADC_ExternalTrigConv_T3_TRGO) || \
6 j/ Y( S$ v8 o9 w. a9 {+ \ - ((REGTRIG) == ADC_ExternalTrigConv_T4_CC4) || \$ Q, W0 E8 k( y1 [9 i# S# X9 a2 W
- ((REGTRIG) == ADC_ExternalTrigConv_T5_CC1) || \
8 J; N5 J- ]/ m l) K3 b) c - ((REGTRIG) == ADC_ExternalTrigConv_T5_CC2) || \
: Z( x' Y$ u. }* j) q+ m - ((REGTRIG) == ADC_ExternalTrigConv_T5_CC3) || \
2 n" M6 P3 h: K) k" g - ((REGTRIG) == ADC_ExternalTrigConv_T8_CC1) || \9 z/ O8 O; @& R
- ((REGTRIG) == ADC_ExternalTrigConv_T8_TRGO) || \
% ~0 U# d" d' q/ H) z) ~) R - ((REGTRIG) == ADC_ExternalTrigConv_Ext_IT11))
3 K0 V3 ^" Q& A! P9 H - /**, ]2 m; l: X8 @3 \) K. l; Q
( ?3 E; U& u5 I# F - */ # W- u) T9 z+ S/ Z6 z
4 S3 q" s) q( c- * }% b8 d* `5 m+ k F5 t
- /** @defgroup ADC_data_align
1 o$ g+ m' V) ]* L% d9 z/ h8 w - * @{
# V5 H. [. q* s5 c - */
M' r+ f, b& j$ l5 l! v4 O' G - #define ADC_DataAlign_Right ((uint32_t)0x00000000)0 S3 J5 M# c% ^) b7 g$ n! w
- #define ADC_DataAlign_Left ((uint32_t)0x00000800)0 ?( j$ B' I7 L5 |
- #define IS_ADC_DATA_ALIGN(ALIGN) (((ALIGN) == ADC_DataAlign_Right) || \
' i/ J1 t1 o/ n; y! X - ((ALIGN) == ADC_DataAlign_Left))$ Q0 O S* ?3 l
- /** J, Q3 u5 p+ _" ?
- * @}7 {& D; \8 m3 Q# _1 @7 V/ d9 _
- */ , f; n& G% _) C! r1 t( D* j& q
" ~ C- p4 y V- " J& i' n3 A$ B
- /** @defgroup ADC_channels 5 V8 v' o$ l6 Q2 ]( I
5 Q/ d5 R f6 ?. I - */
9 Q3 Y- E7 K+ |" p - #define ADC_Channel_0 ((uint8_t)0x00)
" _0 e# l5 I5 @0 X - #define ADC_Channel_1 ((uint8_t)0x01)1 O+ [7 p: }6 P
- #define ADC_Channel_2 ((uint8_t)0x02)( S6 f" }4 E! G# {% b
- #define ADC_Channel_3 ((uint8_t)0x03)
& G- Z; a7 Z( L+ ^; f2 |2 { - #define ADC_Channel_4 ((uint8_t)0x04)/ `: A) m/ l' r9 w' ^) i9 K$ z
- #define ADC_Channel_5 ((uint8_t)0x05)
% h: d( m. \( f! F; ? - #define ADC_Channel_6 ((uint8_t)0x06)) \7 s! y( R+ f! `2 z7 s
- #define ADC_Channel_7 ((uint8_t)0x07)
& k9 X# B$ ]* Y* }& A( M - #define ADC_Channel_8 ((uint8_t)0x08)
) C* q' L6 w/ `$ `" o1 l) t - #define ADC_Channel_9 ((uint8_t)0x09)! J7 g' P. Y. i' |* `0 v
- #define ADC_Channel_10 ((uint8_t)0x0A)( E6 i/ o6 Y* P O# Z, u: U8 K
- #define ADC_Channel_11 ((uint8_t)0x0B)
. n7 e4 G! Q- e: W( V, } - #define ADC_Channel_12 ((uint8_t)0x0C)
1 J. \4 d# v4 F* e! }4 l/ {8 K - #define ADC_Channel_13 ((uint8_t)0x0D)& G+ L' G7 f6 F3 Y7 y& \4 Y
- #define ADC_Channel_14 ((uint8_t)0x0E)
" m5 I5 W5 ~+ F4 u' n - #define ADC_Channel_15 ((uint8_t)0x0F)9 i+ d+ a6 V( t8 X) S; u
- #define ADC_Channel_16 ((uint8_t)0x10)* f; v: e5 T5 g8 K g3 m& v
- #define ADC_Channel_17 ((uint8_t)0x11)
2 t; ?9 u+ F* }" f' O" m - #define ADC_Channel_18 ((uint8_t)0x12)2 C9 L; m0 P! q7 t+ C
- : D1 N4 I6 P$ `0 }
- #if defined (STM32F40_41xxx) || defined(STM32F412xG) || defined(STM32F413_423xx)
v! H: p9 V, ~" ?0 d1 F - #define ADC_Channel_TempSensor ((uint8_t)ADC_Channel_16)6 P' r. K- K6 Y- K0 x
- #endif /* STM32F40_41xxx || STM32F412xG || STM32F413_423xx */
7 r4 W1 s# u, P$ D; @3 o) k; T
4 k& T: k0 S' ]# a, f% n- #if defined (STM32F427_437xx) || defined (STM32F429_439xx) || defined (STM32F401xx) || defined (STM32F410xx) || defined (STM32F411xE)
3 O$ Y' X6 S/ L0 v2 h4 H# ? - #define ADC_Channel_TempSensor ((uint8_t)ADC_Channel_18)
8 M; G( F) L2 O2 R - #endif /* STM32F427_437xx || STM32F429_439xx || STM32F401xx || STM32F410xx || STM32F411xE */
D% U& u, R1 s' ^" G3 n; {- u) f
2 E* \5 H; S ]: ?+ [- #define ADC_Channel_Vrefint ((uint8_t)ADC_Channel_17)
6 Z' f% S, Y2 r6 W - #define ADC_Channel_Vbat ((uint8_t)ADC_Channel_18)
+ a# W" l& n ?6 _ - 7 o! c+ B* ~: u
- #define IS_ADC_CHANNEL(CHANNEL) (((CHANNEL) == ADC_Channel_0) || \1 M; `4 M R2 J" y, v
- ((CHANNEL) == ADC_Channel_1) || \
9 g, O8 j9 E: k2 w2 j - ((CHANNEL) == ADC_Channel_2) || \ i, s7 p' G9 N( O; O/ ^# w
- ((CHANNEL) == ADC_Channel_3) || \$ A* w& G- Q. X: c1 Z
- ((CHANNEL) == ADC_Channel_4) || \# R- P* {9 l% c5 B6 _. ?$ F
- ((CHANNEL) == ADC_Channel_5) || \: T3 A3 K4 y# M% @( N) e% J* d
- ((CHANNEL) == ADC_Channel_6) || \4 G! y7 P4 Q0 e% h7 ] l1 H. \
- ((CHANNEL) == ADC_Channel_7) || \
, k$ _5 v# y0 J* g. W' _1 R - ((CHANNEL) == ADC_Channel_8) || \! S" m, L+ B) T5 k$ ^
- ((CHANNEL) == ADC_Channel_9) || \8 I) v, C) F! s, F3 v# g
- ((CHANNEL) == ADC_Channel_10) || \. l" @( Q+ }* O5 P) L
- ((CHANNEL) == ADC_Channel_11) || \
5 ?/ T: ^4 H- k7 t - ((CHANNEL) == ADC_Channel_12) || \
* U; z( B' n% [+ F, L - ((CHANNEL) == ADC_Channel_13) || \5 e W- h5 k4 c y. m. E
- ((CHANNEL) == ADC_Channel_14) || \) F0 z, p) ^! {4 s" E: H& u' X
- ((CHANNEL) == ADC_Channel_15) || \0 a) x) j, s7 _8 j
- ((CHANNEL) == ADC_Channel_16) || \
9 |# V$ P; A8 P/ l; ?% @7 c - ((CHANNEL) == ADC_Channel_17) || \; {) \9 a1 S D+ l6 h$ a# \
- ((CHANNEL) == ADC_Channel_18))8 c9 }* b# q& M6 b8 u0 \( C' }
- /** Z, J% y' o! w8 ]
' ~+ }! R) L2 e4 { - */
\: S5 a* n9 \# f: X% G - 2 d$ w& L5 [: U4 T+ E; r0 ~; ^, K
- 1 ]$ _! \( ~0 t* T: F4 ]
- /** @defgroup ADC_sampling_times ) e% Q K1 R8 Z: {" ~! z F
- * @{# U8 Z% D7 b, \, k- R7 l8 B7 T
8 g* B+ h: f3 J* Y' a - #define ADC_SampleTime_3Cycles ((uint8_t)0x00)' z8 g- W+ X' B! m
- #define ADC_SampleTime_15Cycles ((uint8_t)0x01)
9 M; q z$ ~; I: E - #define ADC_SampleTime_28Cycles ((uint8_t)0x02)
) O) j4 H( M5 |: j - #define ADC_SampleTime_56Cycles ((uint8_t)0x03): U0 B8 y7 q6 `0 p- B
- #define ADC_SampleTime_84Cycles ((uint8_t)0x04): Y; U, h' b& x0 L) t2 G
- #define ADC_SampleTime_112Cycles ((uint8_t)0x05) g6 X% n2 _: j1 H6 \
- #define ADC_SampleTime_144Cycles ((uint8_t)0x06)! G- ^ j2 t+ T/ w0 x
- #define ADC_SampleTime_480Cycles ((uint8_t)0x07)8 W- t) T( O+ `) a# Y8 E
- #define IS_ADC_SAMPLE_TIME(TIME) (((TIME) == ADC_SampleTime_3Cycles) || \( ? A- U; s) _4 `) T: P
- ((TIME) == ADC_SampleTime_15Cycles) || \
0 `2 V/ e( X+ }8 o - ((TIME) == ADC_SampleTime_28Cycles) || \
6 {7 k8 }6 |6 g3 Y" `5 u - ((TIME) == ADC_SampleTime_56Cycles) || \
; Y% m5 M( p' x5 C - ((TIME) == ADC_SampleTime_84Cycles) || \7 r" D3 n+ c% l7 ~2 k: y! p+ n
- ((TIME) == ADC_SampleTime_112Cycles) || \
& G/ Z- |8 g9 m7 V6 s - ((TIME) == ADC_SampleTime_144Cycles) || \
d' Q d, e& k4 @& a - ((TIME) == ADC_SampleTime_480Cycles))
, I3 u8 j* M! [* Y( Y( Y9 W - /**
/ x" O% ^5 x+ W( Y, J - * @}
# q: c" [& j, Y' L4 J - */ ) H% A+ U% P7 k6 Z! R
. p4 V( \0 l9 x% M) L" x- ; Z2 l( q$ y8 B9 e" ]6 A" B
- /** @defgroup ADC_external_trigger_edge_for_injected_channels_conversion ' ]' ]" k8 k: T% K
* \; Y% m" l2 W. {! b6 }0 r - */ 1 a+ h* ]+ r3 o8 k9 O& J
- #define ADC_ExternalTrigInjecConvEdge_None ((uint32_t)0x00000000)% b9 \* D- g5 T% n4 s% _5 i* f
- #define ADC_ExternalTrigInjecConvEdge_Rising ((uint32_t)0x00100000), _8 f' E1 M- x. s2 z2 B0 m
- #define ADC_ExternalTrigInjecConvEdge_Falling ((uint32_t)0x00200000)
v& i2 F& y6 j! _' P- ?$ [ - #define ADC_ExternalTrigInjecConvEdge_RisingFalling ((uint32_t)0x00300000)" M( {: j @; A) [! N( y. L1 W
- #define IS_ADC_EXT_INJEC_TRIG_EDGE(EDGE) (((EDGE) == ADC_ExternalTrigInjecConvEdge_None) || \: z: X4 M% l' `- D* ?
- ((EDGE) == ADC_ExternalTrigInjecConvEdge_Rising) || \& u0 t" `( `& H, g: J/ o
- ((EDGE) == ADC_ExternalTrigInjecConvEdge_Falling) || \" C* Y! O, {/ c+ y2 h
- ((EDGE) == ADC_ExternalTrigInjecConvEdge_RisingFalling))
. @/ ^3 l6 \/ P - ; p9 T+ Q, a9 q$ \: x
- /**5 l4 P) S; @& [4 d5 E- w
: H* G8 S# Y: \ t - */ 8 r5 M6 B. t# H( ?
3 f* r% G. l6 V* z* D# C- + H; L7 `7 r7 ^3 g) @
- /** @defgroup ADC_extrenal_trigger_sources_for_injected_channels_conversion # H8 U5 C0 s# h( u8 S" x
( U$ j/ m: F+ F q; n - */ 5 s, ^! P5 C' }5 b5 u
- #define ADC_ExternalTrigInjecConv_T1_CC4 ((uint32_t)0x00000000) G8 P0 }( A8 a# v& W
- #define ADC_ExternalTrigInjecConv_T1_TRGO ((uint32_t)0x00010000) L0 X2 b! p1 H) c# @
- #define ADC_ExternalTrigInjecConv_T2_CC1 ((uint32_t)0x00020000). ~# `! w" o. i: `( q( x+ `
- #define ADC_ExternalTrigInjecConv_T2_TRGO ((uint32_t)0x00030000)5 F5 b9 W/ \4 N9 N/ A
- #define ADC_ExternalTrigInjecConv_T3_CC2 ((uint32_t)0x00040000); x% L- [3 ?. C
- #define ADC_ExternalTrigInjecConv_T3_CC4 ((uint32_t)0x00050000)
' u! g7 ^! L u9 U - #define ADC_ExternalTrigInjecConv_T4_CC1 ((uint32_t)0x00060000)0 |3 |3 u& a2 l" X$ P- m1 A
- #define ADC_ExternalTrigInjecConv_T4_CC2 ((uint32_t)0x00070000)
- O5 m7 A' v6 @8 L - #define ADC_ExternalTrigInjecConv_T4_CC3 ((uint32_t)0x00080000); w* d) U4 N. D3 b
- #define ADC_ExternalTrigInjecConv_T4_TRGO ((uint32_t)0x00090000)9 D \9 r4 k" c! t2 W9 y* e: ]
- #define ADC_ExternalTrigInjecConv_T5_CC4 ((uint32_t)0x000A0000)
$ A; c( I, \9 e% y6 [- |. h - #define ADC_ExternalTrigInjecConv_T5_TRGO ((uint32_t)0x000B0000)' x' d+ p9 n* C+ X( M, c& p7 g
- #define ADC_ExternalTrigInjecConv_T8_CC2 ((uint32_t)0x000C0000)
' k+ r, d9 H+ t9 H- N6 F c" W& y& a' ] - #define ADC_ExternalTrigInjecConv_T8_CC3 ((uint32_t)0x000D0000)8 |+ C9 O. y+ W# p3 V( ?( n
- #define ADC_ExternalTrigInjecConv_T8_CC4 ((uint32_t)0x000E0000)5 [% B+ j+ |4 F' X8 Z* y8 S' P
- #define ADC_ExternalTrigInjecConv_Ext_IT15 ((uint32_t)0x000F0000)
/ w) | v& [; X - #define IS_ADC_EXT_INJEC_TRIG(INJTRIG) (((INJTRIG) == ADC_ExternalTrigInjecConv_T1_CC4) || \
6 i7 e# s0 t* _4 Q. Q - ((INJTRIG) == ADC_ExternalTrigInjecConv_T1_TRGO) || \
4 o$ D4 _: m0 V- ?# y7 g* n - ((INJTRIG) == ADC_ExternalTrigInjecConv_T2_CC1) || \4 V2 X; O3 y8 j5 r7 h
- ((INJTRIG) == ADC_ExternalTrigInjecConv_T2_TRGO) || \
% H$ a7 a! M6 g: x - ((INJTRIG) == ADC_ExternalTrigInjecConv_T3_CC2) || \
9 [5 d; }" p' I4 K - ((INJTRIG) == ADC_ExternalTrigInjecConv_T3_CC4) || \; i. V& N+ W* I3 n+ e z
- ((INJTRIG) == ADC_ExternalTrigInjecConv_T4_CC1) || \
) B. I* E" C7 b! g2 W. V3 } - ((INJTRIG) == ADC_ExternalTrigInjecConv_T4_CC2) || \
4 x7 V3 I/ e5 |2 {6 U7 Q" z ^ - ((INJTRIG) == ADC_ExternalTrigInjecConv_T4_CC3) || \& I9 j6 @/ Y0 g* o O' c8 c) u
- ((INJTRIG) == ADC_ExternalTrigInjecConv_T4_TRGO) || \
. [0 b7 O; g0 Q9 n- T9 `# A - ((INJTRIG) == ADC_ExternalTrigInjecConv_T5_CC4) || \
! I, X. u- P# |9 K$ c - ((INJTRIG) == ADC_ExternalTrigInjecConv_T5_TRGO) || \
- [. r0 Z8 c( R2 y3 r" Y" B0 q - ((INJTRIG) == ADC_ExternalTrigInjecConv_T8_CC2) || \; C- o0 Q, E P: [
- ((INJTRIG) == ADC_ExternalTrigInjecConv_T8_CC3) || \1 ]; _! X% p% H' P
- ((INJTRIG) == ADC_ExternalTrigInjecConv_T8_CC4) || \
, K3 u8 X: r3 K, V - ((INJTRIG) == ADC_ExternalTrigInjecConv_Ext_IT15))
$ o" y/ r) f$ s* J0 J) g' g - /**) q) e0 n' p! q* g* x
- * @}: y" X2 X M" f/ i
0 O* Q$ K4 m" S8 S/ L; Y# `
; S9 o2 R& B: j2 d9 o; m4 g- 1 M+ Y( n% W/ p& j/ l5 q% j
- /** @defgroup ADC_injected_channel_selection 3 C$ Y1 h5 _" \4 z9 I. ^
- * @{! d% _* q" n5 A) S
% F2 {; [9 m- E' y. r - #define ADC_InjectedChannel_1 ((uint8_t)0x14)
. O$ r6 d/ s0 F - #define ADC_InjectedChannel_2 ((uint8_t)0x18)8 i( a1 l1 j+ r; c0 e( }
- #define ADC_InjectedChannel_3 ((uint8_t)0x1C)
# I4 {/ H/ R$ A0 c' O2 w - #define ADC_InjectedChannel_4 ((uint8_t)0x20)
- d% W1 y: Q* U5 q) v7 K - #define IS_ADC_INJECTED_CHANNEL(CHANNEL) (((CHANNEL) == ADC_InjectedChannel_1) || \
?9 H9 Y8 C8 s( w* ] - ((CHANNEL) == ADC_InjectedChannel_2) || \
/ X8 } ~, T8 _6 }/ } - ((CHANNEL) == ADC_InjectedChannel_3) || \
% u. b: Y! U2 X1 q% J# ` - ((CHANNEL) == ADC_InjectedChannel_4))8 F! \& U, m( H; E& G* t' A
1 y! v9 q1 ~# H+ ]2 r - * @}; w3 D$ m4 [) l+ m
- */ 6 y& o/ K! S2 a8 p# s' O1 G/ }
- % S6 {3 E) T* ^$ t
. G g: P5 D' F& b) v! v- /** @defgroup ADC_analog_watchdog_selection ) }' A; U5 z# v9 T
- * @{! G X" x0 N; e! Y; R
) w; @4 z9 n Y7 R0 B& n - #define ADC_AnalogWatchdog_SingleRegEnable ((uint32_t)0x00800200)
5 Z0 [# Y5 L* ]% M) `* L - #define ADC_AnalogWatchdog_SingleInjecEnable ((uint32_t)0x00400200)
# z$ E, n3 @# {! y$ A - #define ADC_AnalogWatchdog_SingleRegOrInjecEnable ((uint32_t)0x00C00200)9 y9 Y* L% ?+ y# `. B; j) @% \; M) `% r$ @
- #define ADC_AnalogWatchdog_AllRegEnable ((uint32_t)0x00800000)4 o! h) P2 p0 a' G! a" M! S- T
- #define ADC_AnalogWatchdog_AllInjecEnable ((uint32_t)0x00400000)! r) p, G2 @6 [
- #define ADC_AnalogWatchdog_AllRegAllInjecEnable ((uint32_t)0x00C00000)
3 g4 G% R ^' _! ]/ Y- b5 A - #define ADC_AnalogWatchdog_None ((uint32_t)0x00000000)
: Y8 b6 U5 R6 q8 d1 k4 ` - #define IS_ADC_ANALOG_WATCHDOG(WATCHDOG) (((WATCHDOG) == ADC_AnalogWatchdog_SingleRegEnable) || \
' _" b3 I6 Q! J; n, ? @ - ((WATCHDOG) == ADC_AnalogWatchdog_SingleInjecEnable) || \$ q3 c$ a, ^ j' l6 Q; R+ L- A2 j
- ((WATCHDOG) == ADC_AnalogWatchdog_SingleRegOrInjecEnable) || \! R) x" U8 y4 q i! }0 d" l# |0 ^2 b
- ((WATCHDOG) == ADC_AnalogWatchdog_AllRegEnable) || \
( C x' {: L, X - ((WATCHDOG) == ADC_AnalogWatchdog_AllInjecEnable) || \
4 c$ D# N g% C8 h: H - ((WATCHDOG) == ADC_AnalogWatchdog_AllRegAllInjecEnable) || \
5 q4 [+ s! w, r0 a. J% p - ((WATCHDOG) == ADC_AnalogWatchdog_None)). _% {5 c" }% Z" D
& o& g( |' [; y7 S2 q. J7 u) u2 L - * @}) o. v8 n8 R. x# F. t3 T6 f
- */ + q. Q4 D" u7 }- l9 `9 Z$ p
- ; d' N' j8 g& n! r" l% Y$ Y
- 8 u+ s; E* }3 s- g" ?
- /** @defgroup ADC_interrupts_definition
2 M2 H8 V2 X" w: G; J& x1 R - * @{
, z5 r2 p! k/ e& ~$ O3 H9 t - */
0 G* y: X( J3 J( S9 D - #define ADC_IT_EOC ((uint16_t)0x0205)
. m* F1 ^) g+ T$ M - #define ADC_IT_AWD ((uint16_t)0x0106) - u" m" ~5 m" y9 f |& @% ?" @, h
- #define ADC_IT_JEOC ((uint16_t)0x0407)
/ a$ x2 \9 I# d+ ` D - #define ADC_IT_OVR ((uint16_t)0x201A) 1 |. H* s5 w; V: g* u
- #define IS_ADC_IT(IT) (((IT) == ADC_IT_EOC) || ((IT) == ADC_IT_AWD) || \& E8 x) g: z8 @' m
- ((IT) == ADC_IT_JEOC)|| ((IT) == ADC_IT_OVR)) : C; R( F! ]: d1 p
- /**, T# r' g# Q. e
- * @}' m, U" I( b l" h5 U7 b6 p
$ h7 |: o# k, I* M c& m/ G
5 v) p5 {, x" K" m, A7 ~" M
) Z* p* W% Z# k1 _ H( ?' W- /** @defgroup ADC_flags_definition " u4 s4 |. f, m" n0 ~8 s$ }
- * @{: |: w5 {* o' J- g
- */ $ n% g, e: C# K4 T
- #define ADC_FLAG_AWD ((uint8_t)0x01)
5 m# ^% t" {% K) v' ]) O( \ - #define ADC_FLAG_EOC ((uint8_t)0x02)
8 ]! o e% m/ p9 X6 ~* ?+ c/ V - #define ADC_FLAG_JEOC ((uint8_t)0x04)
+ W1 H0 B# `: x/ R& X$ b9 K - #define ADC_FLAG_JSTRT ((uint8_t)0x08) L f$ c& Z( H7 C3 l: h
- #define ADC_FLAG_STRT ((uint8_t)0x10)1 ` A5 x" s$ t2 ^
- #define ADC_FLAG_OVR ((uint8_t)0x20)
- k+ z( Q0 c* r8 h2 l j# z
4 J2 V' W3 c% }2 M- #define IS_ADC_CLEAR_FLAG(FLAG) ((((FLAG) & (uint8_t)0xC0) == 0x00) && ((FLAG) != 0x00))
$ u' g. c b8 _2 h& w S9 Z: R - #define IS_ADC_GET_FLAG(FLAG) (((FLAG) == ADC_FLAG_AWD) || \2 v: _" Q. E( H
- ((FLAG) == ADC_FLAG_EOC) || \# J% e/ m9 x+ z* f% |% O# _$ h" e
- ((FLAG) == ADC_FLAG_JEOC) || \ n; F8 f* L; I. f" D/ [
- ((FLAG)== ADC_FLAG_JSTRT) || \! h3 B7 X: j; |5 ]2 x7 Z
- ((FLAG) == ADC_FLAG_STRT) || \# ]8 [: A( p& y3 ]) c' p
- ((FLAG)== ADC_FLAG_OVR))
$ O, h2 w) o) p9 V1 Z9 _3 k9 h - /**$ o3 M1 I# t: V- Y
# N- }4 Q& D) n2 ?2 i& U3 w' o - */
9 D, h$ n1 T, W6 ^% p - + }7 S* H4 F6 Q1 C' W; m
- " [3 [+ h7 \4 Z4 T! A& D; S
- /** @defgroup ADC_thresholds ' w( `+ c* L( r6 c( h) |9 s
- g& \# @$ N! w& Y. C - */
3 g; ]& K) s9 D. X. l" t - #define IS_ADC_THRESHOLD(THRESHOLD) ((THRESHOLD) <= 0xFFF)
: j: e- O+ ^! B% u9 F. L - /**/ t5 F* C5 J9 o6 f; ~
- * @}& E/ r1 K, V6 d# y# \
- */ $ u0 N7 ^/ M9 V6 N3 x
5 m' ]/ b; h) c1 q0 _
$ V9 i, \* G+ e; u$ b: A- /** @defgroup ADC_injected_offset 7 v Z. l# [1 j
- * @{, x, G! `; b5 s7 \- D) v* F
6 \) Q) T- R c; S: f - #define IS_ADC_OFFSET(OFFSET) ((OFFSET) <= 0xFFF)
3 N5 Z2 D, i. f% f5 B" g - /**6 W. F/ w" i4 x b- K; Z( D, G
7 W5 n) \# T+ V9 c - */
3 J+ L5 m0 D0 V ^) [
Y9 T$ W. Y/ k% c0 f6 j8 W# ~- ) T5 u& b/ l+ B; ^- g
- /** @defgroup ADC_injected_length 0 D2 x# M+ \" O7 _* F6 D
- * @{& {; |$ ^* O0 d. b4 `% ~. r$ t# N, U2 I
- */ C4 h+ K5 n7 ]/ X
- #define IS_ADC_INJECTED_LENGTH(LENGTH) (((LENGTH) >= 0x1) && ((LENGTH) <= 0x4))
4 {7 u4 F1 d( W# |/ ]* I4 D - /**
! N; ?8 p" |' I3 I' M/ G - * @}+ C6 c' H) g& g" K, ]3 r
, T( u/ F4 R, } Q
7 }7 L. q- Z* J
( ]4 m2 R+ }. `1 a9 t, [- /** @defgroup ADC_injected_rank ) n: { T) y' {( @( U
, V2 J0 R) `5 y8 H4 [4 _2 B- s/ m - */
. s/ \7 G9 m* G( S - #define IS_ADC_INJECTED_RANK(RANK) (((RANK) >= 0x1) && ((RANK) <= 0x4))
5 W" D0 o T8 O5 M - /**
8 h" H: Z, c8 k; m - * @}3 U- R5 {) v& _, f
( |6 ~0 g- \" F7 H+ K( \
8 B3 w5 O) K+ o H' l4 ], x# V
* p) Q& `9 P9 C: k8 W% ]# A( i" c& V; w- /** @defgroup ADC_regular_length % g- N7 ^& E6 u3 [5 ]
- * @{7 X, p2 Z; O0 r
6 V% \! f1 ~ ^# [. j - #define IS_ADC_REGULAR_LENGTH(LENGTH) (((LENGTH) >= 0x1) && ((LENGTH) <= 0x10))
1 ^/ {0 @7 S% m% M2 M) I1 [0 T0 t; v - /**
' s& I H+ `7 N; r$ @ - * @}
9 f7 `5 _: X- l$ R9 T - */ # Q+ S4 E4 J) M; _5 w5 P* G2 V* Y
- , [5 L8 u8 Y( `3 L, x$ N
- Y' H/ p: F8 D7 \: Z
- /** @defgroup ADC_regular_rank
9 K# g' t% B- n/ n0 U - * @{
& E+ q+ i9 I/ ]0 D* V" b9 }1 s( S1 d - */ $ D7 ?8 c- _1 b( Q
- #define IS_ADC_REGULAR_RANK(RANK) (((RANK) >= 0x1) && ((RANK) <= 0x10))
3 w# m" J3 j2 x8 R3 A3 n - /**3 c9 `( K$ ?- n1 P
- * @}# w* ~) j E2 `+ @9 J
+ J2 Q$ W! @$ j! L( x& A- Y0 i5 J: S
+ N) K2 G0 p/ M* P" d; O
9 t% v5 ?. E. |1 ]7 F- /** @defgroup ADC_regular_discontinuous_mode_number 4 _" G/ P# T- M9 z3 r7 ^5 `2 T
- * @{" u* h. d* ]$ m$ z1 n, u
- */ / ~* O; q" j3 d( c1 z
- #define IS_ADC_REGULAR_DISC_NUMBER(NUMBER) (((NUMBER) >= 0x1) && ((NUMBER) <= 0x8))
0 ~# s* ^- e+ @( W1 v - /**
% n0 p2 W V2 ^! A) c8 } - * @}5 q) h' R2 ~9 n! b
复制代码 - n& Z; |3 [8 X" g5 \
03. 相关函数
% s7 @+ \% E1 g" m# c: H- /* Function used to set the ADC configuration to the default reset state *****/ ; o# D! V) E* B$ N
- void ADC_DeInit(void);
3 Q% K% {& F8 G$ n6 v; n n c' x# b
" l+ u5 ?8 \- o Z2 \& `: [) O- /* Initialization and Configuration functions *********************************/ _7 f) H! T V5 P1 Y! o+ o
- void ADC_Init(ADC_TypeDef* ADCx, ADC_InitTypeDef* ADC_InitStruct);8 }6 @8 T0 D0 s1 A0 q$ _
- void ADC_StructInit(ADC_InitTypeDef* ADC_InitStruct);: O4 w% z9 \9 I
- void ADC_CommonInit(ADC_CommonInitTypeDef* ADC_CommonInitStruct);% Y2 l# r* Q( i5 Z4 `/ C5 q
- void ADC_CommonStructInit(ADC_CommonInitTypeDef* ADC_CommonInitStruct);
5 G- ~0 o" b+ b" D1 |3 C - void ADC_Cmd(ADC_TypeDef* ADCx, FunctionalState NewState);7 X: [, x R2 A/ Z
7 s! g! w' E+ V, C% Q6 J- /* Analog Watchdog configuration functions ************************************/
$ \# b% ~2 l+ A, K; S - void ADC_AnalogWatchdogCmd(ADC_TypeDef* ADCx, uint32_t ADC_AnalogWatchdog);
f8 h; W% G2 \& _4 r; G - void ADC_AnalogWatchdogThresholdsConfig(ADC_TypeDef* ADCx, uint16_t HighThreshold,uint16_t LowThreshold);
: S1 C* a$ O, y1 p! q) E$ A - void ADC_AnalogWatchdogSingleChannelConfig(ADC_TypeDef* ADCx, uint8_t ADC_Channel);
9 i$ y$ | }, i - 3 Y% p' ]9 Z4 u5 `" i6 @4 N
- /* Temperature Sensor, Vrefint and VBAT management functions ******************/
( ?8 A' C, H- x% C8 N& i" o - void ADC_TempSensorVrefintCmd(FunctionalState NewState);# O7 j2 `4 v% f/ P1 h D. \- f4 y
- void ADC_VBATCmd(FunctionalState NewState);; h2 ^7 n2 w/ M4 q9 u9 O# g
- 0 V' N( @5 h8 y1 G/ N
- /* Regular Channels Configuration functions ***********************************/5 e, n2 W& n& ~7 \6 I- e6 }& D
- void ADC_RegularChannelConfig(ADC_TypeDef* ADCx, uint8_t ADC_Channel, uint8_t Rank, uint8_t ADC_SampleTime);
8 N ~' f8 u% z' E1 H - void ADC_SoftwareStartConv(ADC_TypeDef* ADCx);( D( D7 @! e' F$ f# O/ b J) k
- FlagStatus ADC_GetSoftwareStartConvStatus(ADC_TypeDef* ADCx);
, g9 D7 B* z H% d" y0 b - void ADC_EOCOnEachRegularChannelCmd(ADC_TypeDef* ADCx, FunctionalState NewState);- y9 B$ L/ t( f# H y
- void ADC_ContinuousModeCmd(ADC_TypeDef* ADCx, FunctionalState NewState);7 K9 S0 M& c+ x9 G" B H" q
- void ADC_DiscModeChannelCountConfig(ADC_TypeDef* ADCx, uint8_t Number);# f: ], b H4 ~* L* x% h: h
- void ADC_DiscModeCmd(ADC_TypeDef* ADCx, FunctionalState NewState);5 e) r( ^! }$ t
- uint16_t ADC_GetConversionValue(ADC_TypeDef* ADCx);8 y! Z* E+ C' i9 W
- uint32_t ADC_GetMultiModeConversionValue(void);
, j+ u2 c( P: `& W) K0 u7 f
7 P2 i4 b: c* J: q$ U- /* Regular Channels DMA Configuration functions *******************************/
& e7 P- R. A1 m4 w* ^ - void ADC_DMACmd(ADC_TypeDef* ADCx, FunctionalState NewState);8 |) S) `+ q" R* Q: H
- void ADC_DMARequestAfterLastTransferCmd(ADC_TypeDef* ADCx, FunctionalState NewState);
* v6 D+ \# \+ z+ A - void ADC_MultiModeDMARequestAfterLastTransferCmd(FunctionalState NewState);9 c W3 @0 {3 T
- * z* Y7 ~6 \ M( Z! ~. K* _8 [
- /* Injected channels Configuration functions **********************************/7 C% l5 Y% s. M2 j
- void ADC_InjectedChannelConfig(ADC_TypeDef* ADCx, uint8_t ADC_Channel, uint8_t Rank, uint8_t ADC_SampleTime);
2 A' K: z0 }8 _$ I/ H - void ADC_InjectedSequencerLengthConfig(ADC_TypeDef* ADCx, uint8_t Length);
5 n4 t% }( n+ L - void ADC_SetInjectedOffset(ADC_TypeDef* ADCx, uint8_t ADC_InjectedChannel, uint16_t Offset);7 M+ Z( `2 G7 {# @2 ^
- void ADC_ExternalTrigInjectedConvConfig(ADC_TypeDef* ADCx, uint32_t ADC_ExternalTrigInjecConv);
. ~$ E/ F! ]* ]* i% `* l S5 s/ y - void ADC_ExternalTrigInjectedConvEdgeConfig(ADC_TypeDef* ADCx, uint32_t ADC_ExternalTrigInjecConvEdge);
& k* ]1 B+ E/ H: t* Z u$ o - void ADC_SoftwareStartInjectedConv(ADC_TypeDef* ADCx);
& O" A0 c2 a1 V- b - FlagStatus ADC_GetSoftwareStartInjectedConvCmdStatus(ADC_TypeDef* ADCx);
7 R; g5 }8 b5 e( F9 c* n - void ADC_AutoInjectedConvCmd(ADC_TypeDef* ADCx, FunctionalState NewState);* _4 F2 ? Q s3 X( Z3 f
- void ADC_InjectedDiscModeCmd(ADC_TypeDef* ADCx, FunctionalState NewState);; |- B/ k3 r" \( `" ?/ s
- uint16_t ADC_GetInjectedConversionValue(ADC_TypeDef* ADCx, uint8_t ADC_InjectedChannel);
2 N# P! R* j# V$ L- R - # Z6 v' Y7 X) F ~ ^: H6 f
- /* Interrupts and flags management functions **********************************/8 r# A3 g/ ^3 |& c( ~: b
- void ADC_ITConfig(ADC_TypeDef* ADCx, uint16_t ADC_IT, FunctionalState NewState);7 r8 m |% ~3 l/ K. l1 p
- FlagStatus ADC_GetFlagStatus(ADC_TypeDef* ADCx, uint8_t ADC_FLAG);
; S) G$ _) T% N5 @% Y - void ADC_ClearFlag(ADC_TypeDef* ADCx, uint8_t ADC_FLAG);& ?0 `( y! @0 \* x4 i
- ITStatus ADC_GetITStatus(ADC_TypeDef* ADCx, uint16_t ADC_IT);8 J9 Y' M4 p9 `% o0 c5 n
- void ADC_ClearITPendingBit(ADC_TypeDef* ADCx, uint16_t ADC_IT);
复制代码 * ?) L" E3 k' i/ x( b
04. 结构体封装" h6 P) ]& T7 k$ S( g& h
- /** 8 E: g$ ^8 v. c& `5 p3 M
- * @brief Analog to Digital Converter
/ I( q `; ?& g% W1 \9 [ - */
5 O$ H3 s$ m+ @# `% N a
8 t z* Z0 j: p; E- typedef struct/ i) \" N/ R' G' s
- {) H( B7 t1 M9 _% D5 ^$ Q
- __IO uint32_t SR; /*!< ADC status register, Address offset: 0x00 */. B h# B, _; p: `0 N
- __IO uint32_t CR1; /*!< ADC control register 1, Address offset: 0x04 */
4 n* r8 B! k8 C+ V: J: | - __IO uint32_t CR2; /*!< ADC control register 2, Address offset: 0x08 */
% I# H. T$ L+ l. k1 `/ t3 u - __IO uint32_t SMPR1; /*!< ADC sample time register 1, Address offset: 0x0C */. p7 B6 X# Y% ?
- __IO uint32_t SMPR2; /*!< ADC sample time register 2, Address offset: 0x10 */& }# g# N/ s1 Q9 O
- __IO uint32_t JOFR1; /*!< ADC injected channel data offset register 1, Address offset: 0x14 */5 ^1 X2 d5 M4 F; M
- __IO uint32_t JOFR2; /*!< ADC injected channel data offset register 2, Address offset: 0x18 */4 ?' Z( N0 a4 R, N! L
- __IO uint32_t JOFR3; /*!< ADC injected channel data offset register 3, Address offset: 0x1C */
8 H7 p: P# t$ V$ d" q - __IO uint32_t JOFR4; /*!< ADC injected channel data offset register 4, Address offset: 0x20 */+ B, E0 O |: T& g3 D# K7 }% n
- __IO uint32_t HTR; /*!< ADC watchdog higher threshold register, Address offset: 0x24 */) f8 b1 H6 { w3 r( k0 I
- __IO uint32_t LTR; /*!< ADC watchdog lower threshold register, Address offset: 0x28 */
- ?1 F* ^3 V1 S3 | - __IO uint32_t SQR1; /*!< ADC regular sequence register 1, Address offset: 0x2C */: l3 O" e: _1 y5 Q4 k N
- __IO uint32_t SQR2; /*!< ADC regular sequence register 2, Address offset: 0x30 */7 O4 @3 P3 w0 O3 b1 g3 V% l
- __IO uint32_t SQR3; /*!< ADC regular sequence register 3, Address offset: 0x34 */& y: a$ K# {* u$ m- t/ h
- __IO uint32_t JSQR; /*!< ADC injected sequence register, Address offset: 0x38 */
/ C8 _3 ~0 @ E, ?3 z. n - __IO uint32_t JDR1; /*!< ADC injected data register 1, Address offset: 0x3C */
# ~) v) g1 n) |9 x$ c! m4 X - __IO uint32_t JDR2; /*!< ADC injected data register 2, Address offset: 0x40 */
( j' H" h h2 @$ l4 Q: s - __IO uint32_t JDR3; /*!< ADC injected data register 3, Address offset: 0x44 */
) q* e) K3 I: g; v+ Y - __IO uint32_t JDR4; /*!< ADC injected data register 4, Address offset: 0x48 */. z% {9 Y2 x# q, Z' k$ Q
- __IO uint32_t DR; /*!< ADC regular data register, Address offset: 0x4C */
/ F% g3 w, I. ^, f! ?4 o% b - } ADC_TypeDef;
' }( [7 [- A( ^! V/ q* J+ W; o
, ~% S$ E/ ^8 n, B) e
复制代码 ) { r1 j$ ~; m" O+ x" ~1 W
7 t: k" Q. i0 `, p
