【经验分享】STM32 HAL库 DS18B20读取温度值
STMCU小助手 发布时间:2022-4-11 10:39
DS18B20.H
. @. d" U. ?, G7 u; m
  1. #ifndef __DS18B20_H$ ]# c, ~) ~7 U  X7 s
  2. #define __DS18B20_H
    # z' [& K% h5 I2 K" Y/ v' Z/ J
  3. $ {. B2 c  U. h: k" F
  4. #include "main.h"
    2 n/ O  o# h$ R& \! }' X
  5. ' x- I* j- d$ i9 g, E4 {* x- I$ h
  6. #define BITBAND(addr, bitnum) ((addr & 0xF0000000)+0x2000000+((addr &0xFFFFF)<<5)+(bitnum<<2))$ C7 a, c6 i, r% I  q$ x( C
  7. #define MEM_ADDR(addr)  *((volatile unsigned long  *)(addr))" w, x1 ~( E/ }
  8. #define BIT_ADDR(addr, bitnum)   MEM_ADDR(BITBAND(addr, bitnum))' Y: Y5 T8 y0 b, N
  9. 0 O) y% A+ ]9 x
  10. #define GPIOA_ODR_Addr    (GPIOA_BASE+12)
    . a0 F. M/ |( i* o& Y
  11. #define GPIOB_ODR_Addr    (GPIOB_BASE+12)# s9 _: y6 A; k
  12. #define GPIOC_ODR_Addr    (GPIOC_BASE+12)6 H- R/ U* [) \& ], o2 N* Z
  13. #define GPIOD_ODR_Addr    (GPIOD_BASE+12)4 b$ ?" a+ |; g6 w2 i- @
  14. #define GPIOE_ODR_Addr    (GPIOE_BASE+12)2 U, D, J, H7 T) J+ S- k; f! Z
  15. #define GPIOF_ODR_Addr    (GPIOF_BASE+12)
    , m( z4 Q, v6 i9 O
  16. #define GPIOG_ODR_Addr    (GPIOG_BASE+12)
    9 P7 ^! P1 {7 L5 {
  17. $ j* h: L, q, l' l; M6 H/ w; J6 o
  18. #define GPIOA_IDR_Addr    (GPIOA_BASE+8)
    ( y+ z% c* ?( c  c: t8 i6 O
  19. #define GPIOB_IDR_Addr    (GPIOB_BASE+8); L! s( V' d, g7 Q
  20. #define GPIOC_IDR_Addr    (GPIOC_BASE+8)
    " ^  L6 ~' ~' X4 V  X. ?
  21. #define GPIOD_IDR_Addr    (GPIOD_BASE+8)1 g* C$ q* l) B, L# w) n! Y& B
  22. #define GPIOE_IDR_Addr    (GPIOE_BASE+8)
    $ O( p% `7 K! m
  23. #define GPIOF_IDR_Addr    (GPIOF_BASE+8)
    , p; v, k1 d1 {/ ]
  24. #define GPIOG_IDR_Addr    (GPIOG_BASE+8)
    9 l) s% P5 U8 L% a3 g5 b
  25. 9 Y" T8 Q& X- H; u3 L8 X: Y
  26. #define PAout(n)   BIT_ADDR(GPIOA_ODR_Addr,n)0 n; \( N2 x3 C2 m0 l. }
  27. #define PAin(n)    BIT_ADDR(GPIOA_IDR_Addr,n)9 b! X5 _+ N5 ^; j/ k- U
  28. 5 l2 d8 Q/ s* ~& b4 Z$ \
  29. #define PBout(n)   BIT_ADDR(GPIOB_ODR_Addr,n)
    - }! G; i3 i$ d, |: q' V
  30. #define PBin(n)    BIT_ADDR(GPIOB_IDR_Addr,n)# r3 K. q1 A. S( G' p* ?
  31. / w& J! X9 R$ R; l; C# G3 {0 |
  32. #define PCout(n)   BIT_ADDR(GPIOC_ODR_Addr,n)
    " q+ C! L2 s4 p3 S
  33. #define PCin(n)    BIT_ADDR(GPIOC_IDR_Addr,n)4 F6 H6 h. h% s8 o) T. R
  34. ) m  T7 c7 n. q) n7 H
  35. #define PDout(n)   BIT_ADDR(GPIOD_ODR_Addr,n); C/ T  q8 X% L' H
  36. #define PDin(n)    BIT_ADDR(GPIOD_IDR_Addr,n), J% q2 y: c# k, }
  37. + Z0 @) e! n  ?, T) `6 V
  38. #define PEout(n)   BIT_ADDR(GPIOE_ODR_Addr,n)
    : ~3 t. [. [- t  c" f
  39. #define PEin(n)    BIT_ADDR(GPIOE_IDR_Addr,n)
    7 y; \8 }/ |1 @# T5 e. u: Q9 a: g
  40. 2 V" s; s# T. l7 l4 F  t2 m
  41. #define PFout(n)   BIT_ADDR(GPIOF_ODR_Addr,n)
    9 A' m7 ^" A+ A8 J* L% n# }, E
  42. #define PFin(n)    BIT_ADDR(GPIOF_IDR_Addr,n)
    % h9 o1 m6 j2 l3 _- j6 {5 ~- ~
  43. + v' m  a) K/ k  ^9 e
  44. #define PGout(n)   BIT_ADDR(GPIOG_ODR_Addr,n)( t* R" K, M) {
  45. #define PGin(n)    BIT_ADDR(GPIOG_IDR_Addr,n)
    . O' W: [- q! [4 i9 F$ a7 D
  46. 1 E' w+ O+ Q2 p. X( }" U
  47. % f9 b) z8 W- ]  s, P
  48. //IO方向设置
      o6 S! A3 Y, }% Y5 ^
  49. #define DS18B20_IO_IN()  {GPIOA->CRL&=0XFFFFFFF0;GPIOA->CRL|=8<<0;}2 P( c. o" i5 @+ R
  50. #define DS18B20_IO_OUT() {GPIOA->CRL&=0XFFFFFFF0;GPIOA->CRL|=3<<0;}
    / x+ r7 V! M' B
  51. 6 V$ X$ r9 F; O; Q7 V1 c- a
  52. //IO操作函数
    % c/ s" Q" j5 J
  53. #define        DS18B20_DQ_OUT PAout(0) //数据端口        PA0) ~7 R8 M! c! Y1 j0 F! E. o
  54. #define        DS18B20_DQ_IN  PAin(0)  //数据端口        PA0 2 m8 |! h) Q0 q: x& H
  55.
    ) T0 K8 l3 z: P$ p8 k2 ^
  56. uint8_t DS18B20_Init(void);                        //初始化DS18B20
    $ d( A1 U% v3 R* \- A6 v
  57. short DS18B20_Get_Temp(void);                //获取温度( Q; v5 v% o+ y6 W! I' Z, N. T
  58. void DS18B20_Start(void);                        //开始温度转换
    ! W$ w7 L; y! B1 v- D- W3 k
  59. void DS18B20_Write_Byte(uint8_t dat);//写入一个字节
    * I' N7 K! I, u# [. G6 h
  60. uint8_t DS18B20_Read_Byte(void);        //读出一个字节: ^) h+ w2 r9 q" y5 w- k
  61. uint8_t DS18B20_Read_Bit(void);                //读出一个位* A; N1 Z. B3 j. M* i
  62. uint8_t DS18B20_Check(void);                //检测是否存在DS18B20  {2 h- o9 u" q7 {# H# q
  63. void DS18B20_Rst(void);                                //复位DS18B20
    & N8 ^5 |; T6 P1 f
  64. #endif
, `) p. J9 x0 x1 O6 Y7 e- `: M3 WDS18B20.C0 G. I9 {# z5 O: J# J
  1. #include "ds18b20.h") c* Q- n  {1 }; c, |( \! ^
  2. - I1 ?6 ]1 l* T$ Q# O! W
  3. static inline void delay_ms(uint32_t delay)0 q; e4 U  t$ w& q3 {$ i, P0 h1 E- e
  4. {
    + C* h6 w4 G' \) t
  5.         HAL_Delay(delay);$ z% O" r/ N, P7 _+ ^: v7 s
  6. }' }! X% e. g% v/ }% i: [  \, ^6 _, _1 B
  7. 5 O# S. }, Q. q6 r3 A$ M6 {
  8. #define CPU_FREQUENCY_MHZ 72                                // CPU主频,根据实际进行修改: N% U& {+ i# j, f" w8 C. d: S
  9. static void delay_us(uint32_t delay)% |9 M6 t$ Y& ?# r( b
  10. {
    - ]5 |9 v+ t; E2 L9 _4 x
  11.         int last, curr, val;
    ) H  z  Y% V2 H' f! a* E
  12.         int temp;% Z+ ^# L1 t" e* }
  13. + L& r5 G; z6 P! U! h2 g
  14.         while (delay != 0)& s0 I; Y$ a# v* a+ X. T6 O
  15.         {  E( a3 t5 j& t0 F0 L- B9 X) Q
  16.                 temp = delay > 900 ? 900 : delay;+ u9 e- [2 Y; q/ C4 T2 O
  17.                 last = SysTick->VAL;# M. }# L, A  I" v) e
  18.                 curr = last - CPU_FREQUENCY_MHZ * temp;7 H/ ~' _( R; P
  19.                 if (curr >= 0)
    # v; N0 w& A% \  g" x0 r
  20.                 {3 n4 P' u5 ?" Y3 L7 w* C
  21.                         do. k* {( G7 A8 R3 U
  22.                         {
    # s( s, _, w( A7 o) s7 X# P
  23.                                 val = SysTick->VAL;
    ' P# \6 S3 N+ l- R( E
  24.                         }
    % s3 \, w. S1 X4 y6 [/ Z3 E
  25.                         while ((val < last) && (val >= curr));
    & M( Z! ]. \  u
  26.                 }
    + n, l8 y3 ~) o; a" i' t+ X
  27.                 else
    ' Z$ p0 |4 @# r* o0 ?/ x% s; O
  28.                 {
    $ P) R, E2 V; x7 T' {% m
  29.                         curr += CPU_FREQUENCY_MHZ * 1000;1 ^7 G" g( C. }8 w
  30.                         do9 a: q+ Y! @/ j) v5 J
  31.                         {
    & m4 u; Y2 ?( X# N) T% X. ~
  32.                                 val = SysTick->VAL;
    & i9 j  B  n# y
  33.                         }
    & {, j' y- r( t$ b) R- T8 B8 T
  34.                         while ((val <= last) || (val > curr));0 l7 O: P! E. b; n
  35.                 }
    " T6 J8 O0 O/ w# h, L
  36.                 delay -= temp;, m& \# d2 M% U; I# c% `
  37.         }7 @  N4 K, E9 y- r8 U
  38. }
    ) H( D! b, o: O# t' n
  39. + N! ^1 `. S  I" G+ g. D
  40. //复位DS18B204 B1 ~/ u  a) i: c
  41. void DS18B20_Rst(void)
    0 w3 g; A- x' j9 D) k
  42. {                 , Q- J2 I7 y0 h# I& x
  43.         DS18B20_IO_OUT(); //SET PA0 OUTPUT1 q, p. ~; z! Z2 S6 v9 W
  44.     DS18B20_DQ_OUT=0; //拉低DQ
    8 ^7 A, J# l6 Q0 w! v! D8 T, f0 V1 L
  45.     delay_us(750);    //拉低750us" {- @! p7 D4 s7 f
  46.     DS18B20_DQ_OUT=1; //DQ=1 & O8 a, @* }: M
  47.         delay_us(15);     //15US
    , N: S" w+ a' v6 \
  48. }, L6 z$ m3 S% c  m
  49. //等待DS18B20的回应
    , D; F" T- r5 y9 n, ?# R
  50. //返回1:未检测到DS18B20的存在
    ' j, T- ]& B7 Q. K/ d" G# a
  51. //返回0:存在  O8 i5 L* h$ S# ~
  52. uint8_t DS18B20_Check(void)3 |! W4 P9 g4 `1 M* J1 Z* |9 E8 Z3 d
  53. {
    - G$ e$ P$ G; w9 X
  54.         uint8_t retry=0;. T+ g$ T5 e* b8 b4 u
  55.         DS18B20_IO_IN();//SET PA0 INPUT         * n; W$ r- q4 A
  56.     while (DS18B20_DQ_IN&&retry<200)/ o" t2 A9 y! G4 Z# S4 f- o
  57.         {5 b& k, n1 k: |* i* A
  58.                 retry++;: l( M* O6 w7 E% F2 ~# K% F" @
  59.                 delay_us(1);
    6 ]* j- k* l. E. D+ G0 O
  60.         };         % S$ H6 q+ E9 `' F* K+ U
  61.         if(retry>=200)return 1;8 B4 W" [2 z6 Z& z# [2 I
  62.         else retry=0;: s. K: z8 I. l4 Z1 ]9 J
  63.     while (!DS18B20_DQ_IN&&retry<240)7 j, t( ~# g1 ~9 f/ z
  64.         {
    7 ~6 N- N7 J2 E
  65.                 retry++;, i8 j& }4 q7 X
  66.                 delay_us(1);) }: c8 u+ a4 L  l" y
  67.         };2 k, e5 c7 P  R; a+ |6 k6 O9 [, A% h
  68.         if(retry>=240)return 1;            ; \! Z5 c1 T- ?6 l
  69.         return 0;3 p9 \* B) Y- y2 j6 P6 b: D
  70. }7 a. ~5 D& _( V1 V5 u* x
  71. //从DS18B20读取一个位% x- n3 ^( }: \1 w) S9 k
  72. //返回值:1/0; H- {1 W. _5 _3 m: w, _. @
  73. uint8_t DS18B20_Read_Bit(void)                          // read one bit2 Y) [$ O- g  H  D5 y
  74. {
    ' y) c- L9 c5 a! u, i7 C. g; Z
  75.     uint8_t data;
    " x9 e4 S6 u$ o9 @# s" X! Z) c  ~
  76.         DS18B20_IO_OUT();//SET PA0 OUTPUT  a/ l( A# R% A( s( \) y* l
  77.     DS18B20_DQ_OUT=0;
    0 O6 ^9 V! L. J. c+ {) E( W
  78.         delay_us(2);. i4 p3 C  k5 n4 G7 R
  79.     DS18B20_DQ_OUT=1;
    5 `' F7 a- M: f) x2 K
  80.         DS18B20_IO_IN();//SET PA0 INPUT8 u5 Y8 G" p2 x. Q
  81.         delay_us(12);
    1 R8 J3 A! P9 {( m6 _/ l1 ?
  82.         if(DS18B20_DQ_IN)data=1;$ y& \* M# V# T0 Y. `2 s8 R
  83.     else data=0;
    7 N6 S  e  ~. O7 _* ?% N/ j8 t5 q
  84.     delay_us(50);
    * F, b; x2 f7 J1 ]2 C. R6 @
  85.     return data;
      ]! }- v# z( b+ [5 U! u
  86. }
    2 O: Z) y/ z% k  \0 Z4 D/ Q
  87. //从DS18B20读取一个字节
    0 k  K2 p( t$ n$ z
  88. //返回值:读到的数据
    ) [* s/ ~) T6 g% W7 F7 G
  89. uint8_t DS18B20_Read_Byte(void)    // read one byte
    " b/ ^8 F* K4 a
  90. {        3 x. |/ l" I0 L6 k' ]6 e
  91.     uint8_t i,j,dat;/ Y; u( x4 V. w6 b. B1 h( N; S
  92.     dat=0;
    ; @  \' q) _: p; A; O* {4 a
  93.         for (i=1;i<=8;i++)
    ) c3 j# @0 g% E6 m  L9 b5 b
  94.         {$ ~; |# E; Y- i& }7 P( c
  95.         j=DS18B20_Read_Bit();
    5 |) W5 E0 c) |7 M3 T: O3 y: U
  96.         dat=(j<<7)|(dat>>1);3 Q9 o0 C7 Y( n$ e
  97.     }                                                    % f  F) Y' U8 E1 L4 m
  98.     return dat;/ }; O9 N) m# J* e0 o7 k& n
  99. }% M. {6 U. w7 g+ t' L8 H( p
  100. //写一个字节到DS18B20
    & J. S8 |/ h0 V- }& M' ^: x
  101. //dat:要写入的字节) F5 X9 F' b1 A
  102. void DS18B20_Write_Byte(uint8_t dat)' O9 B' d! t2 B8 i8 f
  103. {
      ]$ m6 t( [/ @$ f$ O4 `- s
  104.     uint8_t j;. V# j# M! c: {
  105.     uint8_t testb;) d2 B9 t3 g5 T5 V8 S3 `
  106.         DS18B20_IO_OUT();//SET PA0 OUTPUT;
    & ?& `; I. ?9 Q. {
  107.     for (j=1;j<=8;j++)
    ; s) g) k- v) \8 p+ w' U
  108.         {8 }7 V& u/ w+ k0 T8 O% T
  109.         testb=dat&0x01;2 T. d0 h6 m7 ?
  110.         dat=dat>>1;
    % Y+ F- l* i5 F) }
  111.         if (testb)
    : _: ^  S- W4 E0 E4 x, a" c
  112.         {3 `6 |( {7 R/ x( s) v* e) m! @& e* g3 O
  113.             DS18B20_DQ_OUT=0;// Write 1
    * R' O- X, e1 |: ]# `; u6 C
  114.             delay_us(2);
    & K+ n% y' B) \- _* ]5 d
  115.             DS18B20_DQ_OUT=1;
    ' W; z0 z6 ?* E
  116.             delay_us(60);             / D# N" O, K0 x# U! f
  117.         }2 ^- ^/ e7 C" `% b
  118.         else 8 d2 h* {2 z6 k0 j4 x) s
  119.         {
    6 L9 Q4 ]7 m2 Y9 P( s6 O. W9 T
  120.             DS18B20_DQ_OUT=0;// Write 03 n, S; D9 e+ V
  121.             delay_us(60);             " O8 j" p  W" I1 ]9 B& H  V2 e$ Z
  122.             DS18B20_DQ_OUT=1;
    . P; `, F# I; y9 \! i
  123.             delay_us(2);                          % G1 I) |0 s# a0 R) k2 |& D
  124.         }# J9 ?1 h& z. g" I
  125.     }/ N6 j; }/ E* i# e, V( C5 b
  126. }
    / j" s( O: |, D, y! o+ B; O/ J( U, Y
  127. //开始温度转换
    " i, @( G' N1 j4 F" B3 f+ g
  128. void DS18B20_Start(void)// ds1820 start convert/ K! E! X: T9 |% F! r) B
  129. {
    3 Y, c. D; Z6 U4 w/ W$ e
  130.     DS18B20_Rst();
    2 z3 m; k. X1 L: m% S4 e
  131.         DS18B20_Check();         6 d# q2 `* A  j) w1 p* U
  132.     DS18B20_Write_Byte(0xcc);// skip rom
    9 Y8 I9 \8 l& u
  133.     DS18B20_Write_Byte(0x44);// convert
    9 Z; L/ m. k1 |# u! T6 Q% m& y, z
  134. }
    - ^+ J+ n) z* V3 `6 _0 `
  135. //初始化DS18B20的IO口 DQ 同时检测DS的存在) u! w9 N& u" u  J
  136. //返回1:不存在
    2 ]/ p2 d3 d& W( q2 p5 F7 Y: |
  137. //返回0:存在
    + \# J5 @& |% C! @% Q/ F7 l+ G6 l
  138. uint8_t DS18B20_Init(void)
    . g% s/ |2 D2 c( ]
  139. {
    - A. i* F2 Q3 M
  140.         DS18B20_Rst();
    ; v# E/ w$ Q2 G+ a/ P
  141.         return DS18B20_Check();6 y: }% t5 V0 _- s% c( P7 @
  142. }
    * c1 D, T4 }- J5 ~6 W* ]9 H
  143. //从ds18b20得到温度值7 a. @2 d, H/ z/ c2 t4 W
  144. //精度:0.1C
      ]$ n$ i! O- ?. D# t  a
  145. //返回值:温度值 (-550~1250)
    . D0 x! y$ i" B) c. d3 Q
  146. short DS18B20_Get_Temp(void)7 A9 Q5 `5 R, G* M& p+ L7 g& d( U
  147. {
    + S* m8 S: U' P- E, o: ?
  148.     uint8_t temp;
      c) h0 M$ h+ S9 Y# _& Z0 G$ `, b
  149.     uint8_t TL,TH;
    ) W9 t1 F1 [# K" U
  150.         short tem;: c! l, [2 l3 k  f+ A" j, x
  151.     DS18B20_Start ();                    // ds1820 start convert
    7 Z5 U# S1 j( ~) W
  152.     DS18B20_Rst();/ p" K5 t6 ~( ^" h+ c7 g2 O
  153.     DS18B20_Check();
    0 d; w7 P. V, e% p) X6 x' j0 L2 v& g
  154.     DS18B20_Write_Byte(0xcc);// skip rom( [# J6 z& i- h
  155.     DS18B20_Write_Byte(0xbe);// convert            6 \, {$ [1 A$ Z6 ~5 L" d3 |
  156.     TL=DS18B20_Read_Byte(); // LSB
    % q0 I' U5 A+ i
  157.     TH=DS18B20_Read_Byte(); // MSB
    ! q- X% ]- |* V" T" z* [- E
  158.                       1 J8 H3 ]9 `4 m
  159.     if(TH>7)0 j0 r0 v; |! s1 c
  160.     {9 o5 O1 `  L. N; p- ~
  161.         TH=~TH;
    ( o$ l8 `+ u5 W) X% |/ A
  162.         TL=~TL;
    ! C2 E0 E- U: e' M: t
  163.         temp=0;//温度为负  7 E  r/ a6 q, t5 u4 [5 e
  164.     }else temp=1;//温度为正
    ) N' U5 [) O0 H: d
  165.     tem=TH; //获得高八位7 h7 ~6 R6 y& B- B" j
  166.     tem<<=8;    ; ?) }) ]% @; N; ^
  167.     tem+=TL;//获得底八位2 v0 D- o+ a- n0 _# _$ N, t9 f' O
  168.     tem=(float)tem*0.625;//转换     3 G0 H0 [, U/ f0 s: C
  169.         if(temp)return tem; //返回温度值/ l4 I5 u- c! d% p& F, P
  170.         else return -tem;
    2 Y" @8 n/ L. {" \* j
  171. }
    " O: v+ ]1 r' \  h2 D$ n
9 J) F* A1 C" x/ f
9 c) H; Y: d! G/ l  r" i: Y  }  \" Q2 }' g
' u7 |" r9 ]7 Y9 X; a: U& Z( x; @- C/ Z) p# R4 Y9 Q
赞 收藏 评论0 发布时间:2022-4-11 10:39
