【STM32小技巧】+使用DWT代替定时器作为时基
一个脑子不够用 发布时间:2022-10-2 10:29
#include "bsp.h"
! T+ B9 ~: G% u& k6 `9 [" n* J& i) N9 Q
#define  DEM_CR_TRCENA               (1 << 24)4 Q' I# ?- L& S2 v3 v
#define  DWT_CR_CYCCNTENA            (1 <<  0)
+ |& Y0 q% J, j7 ?9 _
' x! F' n" i3 ]! r' E. v! ?1 E4 {; e' s4 f
3 c8 e* W8 a4 l' Q, F; c * @description: 初始化DWT,被Bsp_Init调用
, D# V! h% a4 k+ f- @/ t4 i0 P/ @ * @return {*}* B% y2 a; F% m6 C# `
) [- {; Q. Q. w5 o: _void Bsp_Dwt_Init(void)
1 o: b8 C! b0 X3 k{
, a' L7 S. p9 M2 ^( t$ L        DEM_CR         |= (unsigned int)DEM_CR_TRCENA;   /* Enable Cortex-M's DWT CYCCNT reg. */1 {; i' w1 w# k' J( F* Q
        DWT_CYCCNT      = (unsigned int)0u;
: Q; `1 \$ ^8 o        DWT_CR         |= (unsigned int)DWT_CR_CYCCNTENA;) S; }8 }: I' S' D. t6 e$ O1 q
* K2 J- ~* M+ t' W3 r: s: C) G, w4 U3 Q5 r$ Z
void Bsp_Delay_Ms(uint32_t _ms) - }: q; x" m& a: p
* k6 |1 C! D; u3 ?; T/ N3 \2 I     Bsp_Delay_Us(1000* _ms);; c0 `2 t- e1 ?* `2 P
}. ]1 M. L0 a; l7 }
! y5 v- S$ N/ O% H6 i: O1 f
void Bsp_Delay_Us(uint32_t _us) 7 i" K: S$ Z2 m: c! t
{. t& w  _' f6 Y$ _' Q- [
    uint32_t tCnt, tDelayCnt;$ @% x! g7 h" p
        uint32_t tStart;! B1 C; X" L8 d; s8 Q+ E, U# Y
# I0 a6 \5 a. W9 V9 V        tStart = DWT_CYCCNT;                                     /* 刚进入时的计数器值 */& h7 Z7 u4 ], I; [, Z$ y- s
        tCnt = 0;3 y# J$ A9 Z1 Y% a$ P8 `) [
        tDelayCnt = _us * (SystemCoreClock / 1000000);         /* 需要的节拍数 */                       ; j7 B( s8 \- s( z
  h: _( x, |7 o
        while(tCnt < tDelayCnt)
/ S( v3 e/ ]9 e+ W  @* u        {# P, ?8 o& m, P7 b: g% ?
                tCnt = DWT_CYCCNT - tStart; /* 求减过程中,如果发生第一次32位计数器重新计数,依然可以正确计算 */
: m: P2 O! T, B) H( o$ k        }
+ ]# n! y' P; Z3 n2 w}* Q6 }# P: }1 e$ W  w, B* b/ Q7 Z
7 G) z! ?! |; u' \0 [/ C3 c6 p" T0 Z5 w) w4 k# S/ a) M
void Bsp_Delay_Dwt(uint32_t _dwt)
: X0 D, f- x/ c; ?* N, `) k{9 L) e2 o2 |- q9 Y1 J% ]% }
    uint32_t tCnt, tDelayCnt;# O) I7 t& z9 V' L$ k
        uint32_t tStart;
: T5 O0 [4 A1 E( I+ O5 V5 E3 c% n                % s+ }1 R# q9 ?+ a1 c" S- `
        tCnt = 0;4 A7 g$ O; T0 b
        tDelayCnt = _dwt;         /* 需要的节拍数 */
* |+ W( C  j2 O1 `& ^* @4 X: _1 X        tStart = DWT_CYCCNT;         /* 刚进入时的计数器值 */* c; l0 n1 U# ]0 J
  u/ o$ a% s! D' o1 s        while(tCnt < tDelayCnt)
& \4 J5 c. R- A" |+ D) U! n        {2 C$ |+ a% d$ \, x' W
                tCnt = DWT_CYCCNT - tStart; /* 求减过程中,如果发生第一次32位计数器重新计数,依然可以正确计算 */        6 w  x+ }; z4 i- W% G' X
        }! ]6 g* o4 a: {3 Q; k: i
}) ^# |8 B% y% F/ z
7 B- ]% }2 i# {# Q* z: c% o
9 D- @, N( g9 |void HAL_Delay(uint32_t Delay)# V  s7 ]8 u5 ~
{$ [$ r. A3 o! _1 o' I0 L2 }% y. ?
        Bsp_Delay_Ms(Delay);
2 E! ]$ A9 l7 C$ M}
( p7 q3 W5 a  V* x. U% m! o0 U0 W* X
HAL_StatusTypeDef HAL_InitTick (uint32_t TickPriority)" W' ?0 \; w+ P: Z. e
) F% V+ l( T3 H5 V        return HAL_OK;% ?9 _1 N1 W& f7 _/ s2 d- c8 L
3 W# w9 o4 n& n9 R% i2 h. D  Y3 _/ {8 V/ L0 P4 s) @
uint32_t HAL_GetTick (void) / B$ R& J) V6 O
{+ [/ Z# e7 _+ V/ z+ U
        static uint32_t ticks = 0U;3 {6 z  \2 \' p( j4 g% a6 M- B
        uint32_t i;
( ?7 e+ x1 z; o2 I' h% |* r: [
5 D4 A$ M4 A' h8 w2 v+ P! Q        if (osKernelGetState () == osKernelRunning)
# `, A) G3 \0 f- p5 d. w, v        {
7 A6 z7 K, ~, m                return ((uint32_t)osKernelGetTickCount ());
2 A0 x% H. @$ @: ]5 Q1 @5 Q3 l        }
0 ~2 |6 f& @7 @5 h+ l) R# c  E" C
        /* 如果RTX5还没有运行,采用下面方式 */
2 f9 z! z: f/ Z1 X4 Y1 o& E        for (i = (SystemCoreClock >> 14U); i > 0U; i--)
4 x4 t  ]$ u5 Z5 Q        {
/ x* I% d0 l8 N7 \+ q# v5 t) T                __NOP(); __NOP(); __NOP(); __NOP(); __NOP(); __NOP();, z  U5 q7 ]6 A( J/ ~, m
                __NOP(); __NOP(); __NOP(); __NOP(); __NOP(); __NOP();; n& S4 F% r- p& J
$ s+ U6 r) i& F
* {6 Z/ G9 k) W- E        return ++ticks;
( y5 L1 X0 F7 X- v}
- l; B4 u: n; k1 K
8 h5 Z( Z* }; O& H; l9 q, W* z. {- P  P) H: B
赞 收藏 评论0 发布时间:2022-10-2 10:29
