ST-LINK_gdbserver一直都是卡在等待链接?
xinkunlong 提问时间:2023-11-8 01:01 / 未解决
[0.000] initConfigParams():  Configuration flags start
[0.000] initConfigParams():   external-init                  false
[0.000] initConfigParams():   pend-halt-timeout              (null)
[0.000] initConfigParams():   halt                           false
[0.000] initConfigParams():   config-file                    ""
[0.000] initConfigParams():   persistent                     false
[0.000] initConfigParams():  +log-file                       "/Users/pymcu/micropython/log.log"
[0.000] initConfigParams():   log-level                      31
[0.000] initConfigParams():   port-number                    61234
[0.000] initConfigParams():  +verbose                        true
[0.000] initConfigParams():   refresh-delay                  15
[0.000] initConfigParams():  +verify                         true
[0.000] initConfigParams():  +swd                            true
[0.000] initConfigParams():   swo-port                       61234
[0.000] initConfigParams():   cpu-clock                      8000000
[0.000] initConfigParams():   swo-clock-div                  128
[0.000] initConfigParams():  +initialize-reset               true
[0.000] initConfigParams():   debuggers                      false
[0.000] initConfigParams():   serial-number                  ""
[0.000] initConfigParams():   apid                           0
[0.000] initConfigParams():   attach                         false
[0.000] initConfigParams():  +shared                         true
[0.000] initConfigParams():   erase-all                      false
[0.000] initConfigParams():   memory-map                     ""
[0.000] initConfigParams():   ext-memory-loaders             false
[0.000] initConfigParams():   extload_init                   (null)
[0.000] initConfigParams():   extload                        (null)
[0.000] initConfigParams():  +stm32cubeprogrammer-path       "/opt/ST/STM32CubeCLT/STM32CubeProgrammer/bin/"
[0.000] initConfigParams():   temp-path                      ""
[0.000] initConfigParams():   preserve-temps                 false
[0.000] initConfigParams():   frequency                      0
[0.000] initConfigParams():   licenses                       false
[0.000] initConfigParams():   ignore-rest                    false
[0.000] initConfigParams():   version                        false
[0.000] initConfigParams():   help                           false
[0.000] initConfigParams():  Configuration flags end
[0.000] init():  STMicroelectronics ST-LINK GDB server. Version 7.4.0
Copyright (c) 2023, STMicroelectronics. All rights reserved.
[0.118] openDevice():  COM frequency = 4000 kHz
[0.118] openDevice():  Target connection mode: Under reset
[0.128] readFromTarget():  Reading ROM table for AP 0 @0xe00fdfd0
[0.132] reset_hw_wtchpt_module():  Hardware watchpoint supported by the target
[0.138] initContext():  ST-LINK Firmware version : V2J42M27
[0.138] initContext():  Device ID: 0x451
[0.139] initContext():  PC: 0x8002f8c
[0.139] Device_GetStatus():  ST-LINK device status: HALT_MODE
[0.140] initContext():  ST-LINK detects target voltage = 3.26 V
[0.140] initContext():  ST-LINK device status: HALT_MODE
[0.140] initServerContext():  ST-LINK device initialization OK
[0.140] pollAndNotifyRun():  Stm32Device, pollAndNotify running...
[0.141] updateState():  SwvSrv state change: 0 -> 1
[0.141] WaitConnection():  Waiting for connection on port 61235...
[0.141] WaitConnection():  Waiting for connection on port 61234...
赞 收藏 评论3 发布时间:2023-11-8 01:01
3个回答
xinkunlong 回答时间:2023-11-8 01:03:19
ST-LINK_gdbserver -d -v -t -cp /opt/ST/STM32CubeCLT/STM32CubeProgrammer/bin/ -s -k -f /Users/pymcu/micropython/log.log
在MAC 电脑中,通过指令的方式一直都是处于链接等待状态,但是对应ST-link始终都是处于闪烁状态(红绿交替闪烁)
watershade 回答时间:2023-11-8 14:19:56
xinkunlong 发表于 2023-11-8 01:03</p>
<pre><code class="language-bash">
ST-LINK_gdbserver -d -v -t -cp /opt/ST/STM32CubeCLT/STM32CubeProgrammer/bin/ -s -k -f /U ...
[md]不知道你的是不是Nucleo-U545RE-Q开发板。我用mac也遇到了类似问题。平时那根USB-type-C线连接DAP设备是没问题的。但是尝试用插这个开发板就出现电源灯一直闪烁。用lsusb命令和ls /dev/tty*命令也发现不了设备。后面换一根更好的USB线就可以了。还没有分析电路原理图。
xinkunlong 回答时间:2023-11-8 17:36:22
watershade 发表于 2023-11-8 14:19
不知道你的是不是Nucleo-U545RE-Q开发板。我用mac也遇到了类似问题。平时那根USB-type-C线连接DAP设 ...
[md]使用STM32 IDE 是可以进行 debug的,但是使用指令进行debug的方式就是不行,就一直处于等待连接状态, 使用的是Nucleo-144 STM32F676ZI
