STM32G474VET6 无法进入 USB‑DFU Bootloader 模式
又获得一本《STM32嵌入式系统开发》
STM32CubeMX V1.2.0在中文页面下无法下载,转换到英文页面才行。
请问STM32CubeMX如何下载最新版本,无法登录账号
建议在STM32CubeMX的定时器设置中添加定时时间设置的项目
新一代混合信号MCU STM32G5有什么亮点
cubemx,生成的USB驱动代码,下载到103c8t6上,接上电脑识别不了,有没有人能提供个测试代码
cubemx生成的代码目录, 是否可以支持自定义目录
STM32F103RET6使用cubeMX生成FarFs挂载SD卡,并开启DMA
stm32cubemx 6.18.0 以太网lwip怎么配置
/ USER CODE BEGIN Header / /**
@file hrtim.c
@brief This file provides code for the configuration
of the HRTIM instances.
@attention
Copyright (c) 2026 STMicroelectronics.
All rights reserved.
This software is licensed under terms that can be found in the LICENSE file
in the root directory of this software component.
If no LICENSE file comes with this software, it is provided AS-IS.
/ / USER CODE END Header / / Includes ------------------------------------------------------------------*/
include "hrtim.h"
/ USER CODE BEGIN 0 /
/ USER CODE END 0 /
HRTIM_HandleTypeDef hhrtim1;
/ HRTIM1 init function / void MX_HRTIM1_Init(void) {
/ USER CODE BEGIN HRTIM1_Init 0 /
/ USER CODE END HRTIM1_Init 0 /
HRTIM_EventCfgTypeDef pEventCfg = {0}; HRTIM_FaultBlankingCfgTypeDef pFaultBlkCfg = {0}; HRTIM_FaultCfgTypeDef pFaultCfg = {0}; HRTIM_TimeBaseCfgTypeDef pTimeBaseCfg = {0}; HRTIM_TimerCfgTypeDef pTimerCfg = {0}; HRTIM_TimerCtlTypeDef pTimerCtl = {0}; HRTIM_CompareCfgTypeDef pCompareCfg = {0}; HRTIM_DeadTimeCfgTypeDef pDeadTimeCfg = {0}; HRTIM_OutputCfgTypeDef pOutputCfg = {0};
/ USER CODE BEGIN HRTIM1_Init 1 /
/ USER CODE END HRTIM1_Init 1 / hhrtim1.Instance = HRTIM1; hhrtim1.Init.HRTIMInterruptResquests = HRTIM_IT_NONE; hhrtim1.Init.SyncOptions = HRTIM_SYNCOPTION_NONE;
if (HAL_HRTIM_Init(&hhrtim1) != HAL_OK) { Error_Handler(); }
if (HAL_HRTIM_DLLCalibrationStart(&hhrtim1, HRTIM_CALIBRATIONRATE_3) != HAL_OK) { Error_Handler(); }
if (HAL_HRTIM_PollForDLLCalibration(&hhrtim1, 10) != HAL_OK) { Error_Handler(); }
if (HAL_HRTIM_EventPrescalerConfig(&hhrtim1, HRTIM_EVENTPRESCALER_DIV1) != HAL_OK) { Error_Handler(); }
pEventCfg.Source = HRTIM_EEV1SRC_COMP2_OUT; pEventCfg.Polarity = HRTIM_EVENTPOLARITY_HIGH; pEventCfg.Sensitivity = HRTIM_EVENTSENSITIVITY_LEVEL; pEventCfg.FastMode = HRTIM_EVENTFASTMODE_DISABLE;
if (HAL_HRTIM_EventConfig(&hhrtim1, HRTIM_EVENT_1, &pEventCfg) != HAL_OK) { Error_Handler(); }
pEventCfg.Source = HRTIM_EEV4SRC_COMP1_OUT;
if (HAL_HRTIM_EventConfig(&hhrtim1, HRTIM_EVENT_4, &pEventCfg) != HAL_OK) { Error_Handler(); }
pEventCfg.Source = HRTIM_EEV10SRC_GPIO; pEventCfg.Filter = HRTIM_EVENTFILTER_NONE;
if (HAL_HRTIM_EventConfig(&hhrtim1, HRTIM_EVENT_10, &pEventCfg) != HAL_OK) { Error_Handler(); }
if (HAL_HRTIM_FaultPrescalerConfig(&hhrtim1, HRTIM_FAULTPRESCALER_DIV1) != HAL_OK) { Error_Handler(); }
pFaultBlkCfg.Threshold = 0; pFaultBlkCfg.ResetMode = HRTIM_FAULTCOUNTERRST_UNCONDITIONAL; pFaultBlkCfg.BlankingSource = HRTIM_FAULTBLANKINGMODE_RSTALIGNED;
if (HAL_HRTIM_FaultCounterConfig(&hhrtim1, HRTIM_FAULT_5, &pFaultBlkCfg) != HAL_OK) { Error_Handler(); }
if (HAL_HRTIM_FaultBlankingConfigAndEnable(&hhrtim1, HRTIM_FAULT_5, &pFaultBlkCfg) != HAL_OK) { Error_Handler(); }
pFaultCfg.Source = HRTIM_FAULTSOURCE_DIGITALINPUT; pFaultCfg.Polarity = HRTIM_FAULTPOLARITY_HIGH; pFaultCfg.Filter = HRTIM_FAULTFILTER_NONE; pFaultCfg.Lock = HRTIM_FAULTLOCK_READWRITE;
if (HAL_HRTIM_FaultConfig(&hhrtim1, HRTIM_FAULT_5, &pFaultCfg) != HAL_OK) { Error_Handler(); }
HAL_HRTIM_FaultModeCtl(&hhrtim1, HRTIM_FAULT_5, HRTIM_FAULTMODECTL_ENABLED); pTimeBaseCfg.Period = 5000; pTimeBaseCfg.RepetitionCounter = 0x00; pTimeBaseCfg.PrescalerRatio = HRTIM_PRESCALERRATIO_MUL2; pTimeBaseCfg.Mode = HRTIM_MODE_CONTINUOUS;
if (HAL_HRTIM_TimeBaseConfig(&hhrtim1, HRTIM_TIMERINDEX_MASTER, &pTimeBaseCfg) != HAL_OK) { Error_Handler(); }
pTimerCfg.InterruptRequests = HRTIM_MASTER_IT_NONE; pTimerCfg.DMARequests = HRTIM_MASTER_DMA_NONE; pTimerCfg.DMASrcAddress = 0x0000; pTimerCfg.DMADstAddress = 0x0000; pTimerCfg.DMASize = 0x1; pTimerCfg.HalfModeEnable = HRTIM_HALFMODE_DISABLED; pTimerCfg.InterleavedMode = HRTIM_INTERLEAVED_MODE_QUAD; pTimerCfg.StartOnSync = HRTIM_SYNCSTART_DISABLED; pTimerCfg.ResetOnSync = HRTIM_SYNCRESET_DISABLED; pTimerCfg.DACSynchro = HRTIM_DACSYNC_NONE; pTimerCfg.PreloadEnable = HRTIM_PRELOAD_DISABLED; pTimerCfg.UpdateGating = HRTIM_UPDATEGATING_INDEPENDENT; pTimerCfg.BurstMode = HRTIM_TIMERBURSTMODE_MAINTAINCLOCK; pTimerCfg.RepetitionUpdate = HRTIM_UPDATEONREPETITION_DISABLED; pTimerCfg.ReSyncUpdate = HRTIM_TIMERESYNC_UPDATE_UNCONDITIONAL;
if (HAL_HRTIM_WaveformTimerConfig(&hhrtim1, HRTIM_TIMERINDEX_MASTER, &pTimerCfg) != HAL_OK) { Error_Handler(); }
pCompareCfg.CompareValue = 4999;
if (HAL_HRTIM_WaveformCompareConfig(&hhrtim1, HRTIM_TIMERINDEX_MASTER, HRTIM_COMPAREUNIT_4, &pCompareCfg) != HAL_OK) { Error_Handler(); }
pTimeBaseCfg.Period = 20000;
if (HAL_HRTIM_TimeBaseConfig(&hhrtim1, HRTIM_TIMERINDEX_TIMER_A, &pTimeBaseCfg) != HAL_OK) { Error_Handler(); }
/------------------ 配置HRTIM TRG2用于ADC触发 ------------------/ /**
if (HAL_HRTIM_ADCTriggerConfig(&hhrtim1, HRTIM_ADCTRIGGER_2, &pAdcTrigCfg) != HAL_OK) { Error_Handler(); } // if (HAL_HRTIM_ADCPostScalerConfig(&hhrtim1, HRTIM_ADCTRIGGER_2, 0x0) != HAL_OK) // { // Error_Handler(); // }
pAdcTrigCfg.UpdateSource = HRTIM_ADCTRIGGERUPDATE_MASTER; pAdcTrigCfg.Trigger = HRTIM_ADCTRIGGEREVENT24_TIMERC_CMP2|HRTIM_ADCTRIGGEREVENT24_TIMERC_CMP4 |HRTIM_ADCTRIGGEREVENT24_TIMERD_CMP2|HRTIM_ADCTRIGGEREVENT24_TIMERD_CMP4;
if (HAL_HRTIM_ADCTriggerConfig(&hhrtim1, HRTIM_ADCTRIGGER_4, &pAdcTrigCfg) != HAL_OK) { Error_Handler(); } // if (HAL_HRTIM_ADCPostScalerConfig(&hhrtim1, HRTIM_ADCTRIGGER_4, 0x0) != HAL_OK) // { // Error_Handler(); // }
pTimerCtl.UpDownMode = HRTIM_TIMERUPDOWNMODE_UP; pTimerCtl.GreaterCMP1 = HRTIM_TIMERGTCMP1_EQUAL; pTimerCtl.DualChannelDacEnable = HRTIM_TIMER_DCDE_DISABLED;
if (HAL_HRTIM_WaveformTimerControl(&hhrtim1, HRTIM_TIMERINDEX_TIMER_A, &pTimerCtl) != HAL_OK) { Error_Handler(); }
pTimerCfg.InterruptRequests = HRTIM_TIM_IT_NONE; pTimerCfg.DMARequests = HRTIM_TIM_DMA_NONE; pTimerCfg.InterleavedMode = HRTIM_INTERLEAVED_MODE_DISABLED; pTimerCfg.PreloadEnable = HRTIM_PRELOAD_ENABLED; pTimerCfg.RepetitionUpdate = HRTIM_UPDATEONREPETITION_ENABLED; pTimerCfg.PushPull = HRTIM_TIMPUSHPULLMODE_DISABLED; pTimerCfg.FaultEnable = HRTIM_TIMFAULTENABLE_NONE; pTimerCfg.FaultLock = HRTIM_TIMFAULTLOCK_READWRITE; pTimerCfg.DeadTimeInsertion = HRTIM_TIMDEADTIMEINSERTION_DISABLED; pTimerCfg.DelayedProtectionMode = HRTIM_TIMER_A_B_C_DELAYEDPROTECTION_DISABLED; pTimerCfg.UpdateTrigger = HRTIM_TIMUPDATETRIGGER_NONE; pTimerCfg.ResetTrigger = HRTIM_TIMRESETTRIGGER_MASTER_PER; pTimerCfg.ResetUpdate = HRTIM_TIMUPDATEONRESET_ENABLED;
if (HAL_HRTIM_WaveformTimerConfig(&hhrtim1, HRTIM_TIMERINDEX_TIMER_A, &pTimerCfg) != HAL_OK) { Error_Handler(); }
pTimerCfg.ResetTrigger = HRTIM_TIMRESETTRIGGER_MASTER_CMP1;
if (HAL_HRTIM_WaveformTimerConfig(&hhrtim1, HRTIM_TIMERINDEX_TIMER_B, &pTimerCfg) != HAL_OK) { Error_Handler(); }
pTimerCfg.ResetTrigger = HRTIM_TIMRESETTRIGGER_MASTER_CMP2;
if (HAL_HRTIM_WaveformTimerConfig(&hhrtim1, HRTIM_TIMERINDEX_TIMER_C, &pTimerCfg) != HAL_OK) { Error_Handler(); }
pTimerCfg.DelayedProtectionMode = HRTIM_TIMER_D_E_DELAYEDPROTECTION_DISABLED; pTimerCfg.ResetTrigger = HRTIM_TIMRESETTRIGGER_MASTER_CMP3;
if (HAL_HRTIM_WaveformTimerConfig(&hhrtim1, HRTIM_TIMERINDEX_TIMER_D, &pTimerCfg) != HAL_OK) { Error_Handler(); }
/------------------ 配置A、B、C、D定时器的CMP1 ------------------/ pCompareCfg.CompareValue = 2000;
if (HAL_HRTIM_WaveformCompareConfig(&hhrtim1, HRTIM_TIMERINDEX_TIMER_A, HRTIM_COMPAREUNIT_1, &pCompareCfg) != HAL_OK) { Error_Handler(); }
if (HAL_HRTIM_WaveformCompareConfig(&hhrtim1, HRTIM_TIMERINDEX_TIMER_B, HRTIM_COMPAREUNIT_1, &pCompareCfg) != HAL_OK) { Error_Handler(); }
if (HAL_HRTIM_WaveformCompareConfig(&hhrtim1, HRTIM_TIMERINDEX_TIMER_C, HRTIM_COMPAREUNIT_1, &pCompareCfg) != HAL_OK) { Error_Handler(); }
if (HAL_HRTIM_WaveformCompareConfig(&hhrtim1, HRTIM_TIMERINDEX_TIMER_D, HRTIM_COMPAREUNIT_1, &pCompareCfg) != HAL_OK) { Error_Handler(); }
/------------------ 配置A、B、C、D定时器的CMP2 (用于ADC触发) ------------------/ /**
*/ pCompareCfg.CompareValue = 200;
if (HAL_HRTIM_WaveformCompareConfig(&hhrtim1, HRTIM_TIMERINDEX_TIMER_A, HRTIM_COMPAREUNIT_2, &pCompareCfg) != HAL_OK) { Error_Handler(); } pCompareCfg.CompareValue = 5000 / 4 + 200; if (HAL_HRTIM_WaveformCompareConfig(&hhrtim1, HRTIM_TIMERINDEX_TIMER_B, HRTIM_COMPAREUNIT_2, &pCompareCfg) != HAL_OK) { Error_Handler(); } pCompareCfg.CompareValue = 5000 / 4 2 + 200; if (HAL_HRTIM_WaveformCompareConfig(&hhrtim1, HRTIM_TIMERINDEX_TIMER_C, HRTIM_COMPAREUNIT_2, &pCompareCfg) != HAL_OK) { Error_Handler(); } pCompareCfg.CompareValue = 5000 / 4 3 + 200; if (HAL_HRTIM_WaveformCompareConfig(&hhrtim1, HRTIM_TIMERINDEX_TIMER_D, HRTIM_COMPAREUNIT_2, &pCompareCfg) != HAL_OK) { Error_Handler(); }
pCompareCfg.CompareValue = 400;
if (HAL_HRTIM_WaveformCompareConfig(&hhrtim1, HRTIM_TIMERINDEX_TIMER_A, HRTIM_COMPAREUNIT_4, &pCompareCfg) != HAL_OK) { Error_Handler(); } pCompareCfg.CompareValue = 5000 / 4 + 400; if (HAL_HRTIM_WaveformCompareConfig(&hhrtim1, HRTIM_TIMERINDEX_TIMER_B, HRTIM_COMPAREUNIT_4, &pCompareCfg) != HAL_OK) { Error_Handler(); } pCompareCfg.CompareValue = 5000 / 4 2 + 400; if (HAL_HRTIM_WaveformCompareConfig(&hhrtim1, HRTIM_TIMERINDEX_TIMER_C, HRTIM_COMPAREUNIT_4, &pCompareCfg) != HAL_OK) { Error_Handler(); } pCompareCfg.CompareValue = 5000 / 4 3 + 400; if (HAL_HRTIM_WaveformCompareConfig(&hhrtim1, HRTIM_TIMERINDEX_TIMER_D, HRTIM_COMPAREUNIT_4, &pCompareCfg) != HAL_OK) { Error_Handler(); }
pDeadTimeCfg.Prescaler = HRTIM_TIMDEADTIME_PRESCALERRATIO_DIV1; pDeadTimeCfg.RisingValue = 1; pDeadTimeCfg.RisingSign = HRTIM_TIMDEADTIME_RISINGSIGN_POSITIVE; pDeadTimeCfg.RisingLock = HRTIM_TIMDEADTIME_RISINGLOCK_WRITE; pDeadTimeCfg.RisingSignLock = HRTIM_TIMDEADTIME_RISINGSIGNLOCK_WRITE; pDeadTimeCfg.FallingValue = 1; pDeadTimeCfg.FallingSign = HRTIM_TIMDEADTIME_FALLINGSIGN_POSITIVE; pDeadTimeCfg.FallingLock = HRTIM_TIMDEADTIME_FALLINGLOCK_WRITE; pDeadTimeCfg.FallingSignLock = HRTIM_TIMDEADTIME_FALLINGSIGNLOCK_WRITE;
if (HAL_HRTIM_DeadTimeConfig(&hhrtim1, HRTIM_TIMERINDEX_TIMER_A, &pDeadTimeCfg) != HAL_OK) { Error_Handler(); }
if (HAL_HRTIM_DeadTimeConfig(&hhrtim1, HRTIM_TIMERINDEX_TIMER_B, &pDeadTimeCfg) != HAL_OK) { Error_Handler(); }
if (HAL_HRTIM_DeadTimeConfig(&hhrtim1, HRTIM_TIMERINDEX_TIMER_C, &pDeadTimeCfg) != HAL_OK) { Error_Handler(); }
if (HAL_HRTIM_DeadTimeConfig(&hhrtim1, HRTIM_TIMERINDEX_TIMER_D, &pDeadTimeCfg) != HAL_OK) { Error_Handler(); }
pOutputCfg.Polarity = HRTIM_OUTPUTPOLARITY_HIGH; pOutputCfg.SetSource = HRTIM_OUTPUTSET_MASTERPER; pOutputCfg.ResetSource = HRTIM_OUTPUTRESET_TIMCMP1|HRTIM_OUTPUTSET_EEV_1 |HRTIM_OUTPUTSET_EEV_4; pOutputCfg.IdleMode = HRTIM_OUTPUTIDLEMODE_NONE; pOutputCfg.IdleLevel = HRTIM_OUTPUTIDLELEVEL_INACTIVE; pOutputCfg.FaultLevel = HRTIM_OUTPUTFAULTLEVEL_NONE; pOutputCfg.ChopperModeEnable = HRTIM_OUTPUTCHOPPERMODE_DISABLED; pOutputCfg.BurstModeEntryDelayed = HRTIM_OUTPUTBURSTMODEENTRY_REGULAR;
if (HAL_HRTIM_WaveformOutputConfig(&hhrtim1, HRTIM_TIMERINDEX_TIMER_A, HRTIM_OUTPUT_TA1, &pOutputCfg) != HAL_OK) { Error_Handler(); }
pOutputCfg.SetSource = HRTIM_OUTPUTSET_MASTERCMP1; pOutputCfg.ResetSource = HRTIM_OUTPUTRESET_TIMCMP1;
if (HAL_HRTIM_WaveformOutputConfig(&hhrtim1, HRTIM_TIMERINDEX_TIMER_B, HRTIM_OUTPUT_TB1, &pOutputCfg) != HAL_OK) { Error_Handler(); }
pOutputCfg.SetSource = HRTIM_OUTPUTSET_MASTERCMP2;
if (HAL_HRTIM_WaveformOutputConfig(&hhrtim1, HRTIM_TIMERINDEX_TIMER_C, HRTIM_OUTPUT_TC1, &pOutputCfg) != HAL_OK) { Error_Handler(); }
pOutputCfg.SetSource = HRTIM_OUTPUTSET_MASTERCMP3;
if (HAL_HRTIM_WaveformOutputConfig(&hhrtim1, HRTIM_TIMERINDEX_TIMER_D, HRTIM_OUTPUT_TD1, &pOutputCfg) != HAL_OK) { Error_Handler(); }
pOutputCfg.SetSource = HRTIM_OUTPUTSET_NONE; pOutputCfg.ResetSource = HRTIM_OUTPUTRESET_NONE;
if (HAL_HRTIM_WaveformOutputConfig(&hhrtim1, HRTIM_TIMERINDEX_TIMER_A, HRTIM_OUTPUT_TA2, &pOutputCfg) != HAL_OK) { Error_Handler(); }
if (HAL_HRTIM_WaveformOutputConfig(&hhrtim1, HRTIM_TIMERINDEX_TIMER_B, HRTIM_OUTPUT_TB2, &pOutputCfg) != HAL_OK) { Error_Handler(); }
if (HAL_HRTIM_WaveformOutputConfig(&hhrtim1, HRTIM_TIMERINDEX_TIMER_C, HRTIM_OUTPUT_TC2, &pOutputCfg) != HAL_OK) { Error_Handler(); }
if (HAL_HRTIM_WaveformOutputConfig(&hhrtim1, HRTIM_TIMERINDEX_TIMER_D, HRTIM_OUTPUT_TD2, &pOutputCfg) != HAL_OK) { Error_Handler(); }
if (HAL_HRTIM_TimeBaseConfig(&hhrtim1, HRTIM_TIMERINDEX_TIMER_B, &pTimeBaseCfg) != HAL_OK) { Error_Handler(); }
if (HAL_HRTIM_WaveformTimerControl(&hhrtim1, HRTIM_TIMERINDEX_TIMER_B, &pTimerCtl) != HAL_OK) { Error_Handler(); }
// pCompareCfg.CompareValue = 2000;
// if (HAL_HRTIM_WaveformCompareConfig(&hhrtim1, HRTIM_TIMERINDEX_TIMER_B, HRTIM_COMPAREUNIT_1, &pCompareCfg) != HAL_OK) // { // Error_Handler(); // }
if (HAL_HRTIM_TimeBaseConfig(&hhrtim1, HRTIM_TIMERINDEX_TIMER_C, &pTimeBaseCfg) != HAL_OK) { Error_Handler(); }
if (HAL_HRTIM_WaveformTimerControl(&hhrtim1, HRTIM_TIMERINDEX_TIMER_C, &pTimerCtl) != HAL_OK) { Error_Handler(); }
// pCompareCfg.CompareValue = 3000;
// if (HAL_HRTIM_WaveformCompareConfig(&hhrtim1, HRTIM_TIMERINDEX_TIMER_C, HRTIM_COMPAREUNIT_1, &pCompareCfg) != HAL_OK) // { // Error_Handler(); // }
if (HAL_HRTIM_TimeBaseConfig(&hhrtim1, HRTIM_TIMERINDEX_TIMER_D, &pTimeBaseCfg) != HAL_OK) { Error_Handler(); }
if (HAL_HRTIM_WaveformTimerControl(&hhrtim1, HRTIM_TIMERINDEX_TIMER_D, &pTimerCtl) != HAL_OK) { Error_Handler(); }
// pCompareCfg.CompareValue = 4000;
// if (HAL_HRTIM_WaveformCompareConfig(&hhrtim1, HRTIM_TIMERINDEX_TIMER_D, HRTIM_COMPAREUNIT_1, &pCompareCfg) != HAL_OK) // { // Error_Handler(); // }
/ USER CODE BEGIN HRTIM1_Init 2 /
/ USER CODE END HRTIM1_Init 2 / HAL_HRTIM_MspPostInit(&hhrtim1); }
void HAL_HRTIM_MspInit(HRTIM_HandleTypeDef* hrtimHandle) {
GPIO_InitTypeDef GPIO_InitStruct = {0};
if (hrtimHandle->Instance==HRTIM1) { / USER CODE BEGIN HRTIM1_MspInit 0 /
void HAL_HRTIM_MspPostInit(HRTIM_HandleTypeDef* hrtimHandle) {
if (hrtimHandle->Instance==HRTIM1) { / USER CODE BEGIN HRTIM1_MspPostInit 0 /
void HAL_HRTIM_MspDeInit(HRTIM_HandleTypeDef* hrtimHandle) {
if (hrtimHandle->Instance==HRTIM1) { / USER CODE BEGIN HRTIM1_MspDeInit 0 /
/ USER CODE BEGIN 1 / void HAL_HRTIM_RepetitionEventCallback(HRTIM_HandleTypeDef *hhrtim, uint32_t TimerIdx) { if (TimerIdx == HRTIM_TIMERINDEX_MASTER) {
// HAL_GPIO_WritePin(GPIOC, GPIO_PIN_9, GPIO_PIN_RESET); } } / USER CODE END 1 /
这里贴的代码看起来太费劲了。
你到底用到几个ADC模块?要用到4个来自HRTIM的触发事件?
HRTIM参数4个ADC的触发事件倒是可以,而且你都是要用各TIM的CMP2事件。
但没明白你具体想怎么使用?我看你只提到2个ADC模块。能描述详细点吗?
哦
我刚才又看了下,你好像是想每个来自HRTIM的触发事件,包含2个TIM事件触发源。
这个原理上应该是可以的。
G474应该也有内部tim级联adc的配置吧。你描述的太粗糙,建议自己看一下rm看看
