BootLoader:4 V* z$ {9 W7 y) N& L
$ G# @4 P$ \. p8 \5 ]main里调用函数跳转到APP地址0x8003000/ ]/ s) Y3 w& u3 B6 S
" h: n* d8 M% h8 G: W- y9 C0 G
- typedef void (*pFunction)(void);
复制代码- #define ApplicationAddress 0x8003000
复制代码- void UserAppStart(void)
, ?5 u; n) J7 {( c) P( D - {
3 {! C0 |: ^7 ] - if (((*(__IO uint32_t*)ApplicationAddress) & 0x2FFE0000 ) == 0x20000000)$ }9 y. ~4 ^0 f8 A0 {: s
1 W: l& p7 {) b" B8 q) } - /* Jump to user application */
. m1 w4 ?+ I: H$ W) x6 {: T9 S% R - JumpAddress = *(__IO uint32_t*) (ApplicationAddress + 4);% W( T: C$ j4 Z, G8 i
- Jump_To_Application = (pFunction) JumpAddress;) k. w6 K! C7 h3 x& g
- /* Initialize user application's Stack Pointer */6 Y0 M3 |- i9 \$ R, j4 }+ z) j! y
- __set_MSP(*(__IO uint32_t*) ApplicationAddress);# k/ l7 J/ m8 Z3 j/ ]
- Jump_To_Application();: U3 R0 m4 s3 _4 a1 T
- }1 u# x1 j2 b1 v* \- C& j7 P
& B8 t3 z" ~: a! |! X! |APP:
. a Q# u5 @- G9 L0 s" m$ n, d5 \1 G2 J
main 函数添加, |) O# w. v9 N% W5 n
+ ]! C0 B$ d7 V0 ~9 @( o& m- #define APPLICATION_ADDRESS ((uint32_t)0x08003000): w+ l% i3 i* F- h
- #if (defined ( __CC_ARM ))' H/ R" c D- ~3 v+ l
- __IO uint32_t VectorTable[48] __attribute__((at(0x20000000)));
# X3 D6 `& N a5 n# h7 d+ V" p1 [ - #elif (defined (__ICCARM__))
7 [/ y% \5 E+ t: H. p - #pragma location = 0x20000000
, U! M# V4 p B& y4 i% J( E - __no_init __IO uint32_t VectorTable[48];2 C. {) }; C$ p* e% F& G+ F
- #elif defined ( __GNUC__ )
/ ?; k+ U% S9 F& Y - __IO uint32_t VectorTable[48] __attribute__((section(".RAMVectorTable")));, e, v; N4 {4 G" V7 j" L
- #elif defined ( __TASKING__ )9 d% U( V# B& f- T1 S9 J- o
- __IO uint32_t VectorTable[48] __at(0x20000000);
- j/ G5 b4 ^! l - #endif
复制代码- /* USER CODE BEGIN 1 */
# v3 K1 |$ W& m5 b - uint32_t i = 0;
复制代码- /* Relocate by software the vector table to the internal SRAM at 0x20000000 ***/ ; u0 L8 v9 D4 c
- . a: T# e5 K- t- V
- /* Copy the vector table from the Flash (mapped at the base of the application
0 ?+ w) Y; Y9 W0 ?7 {1 h% Z - load address 0x08003000) to the base address of the SRAM at 0x20000000. */) S+ ?5 N9 C3 v% R/ K. p2 K% H
* ^. Z5 Q: A6 ~9 l* N9 V7 r4 B- for(i = 0; i < 48; i++)
. I2 e: h7 f3 k3 ]" g/ A9 T. [$ M - {
1 m& f, |/ A4 L" m7 K1 P - VectorTable<i> = *(__IO uint32_t*)(APPLICATION_ADDRESS + (i<<2));</i>" G/ Z( j* g* U/ ~
0 @' K# j( U* L3 b3 Q - // Enable the SYSCFG peripheral clock
5 n8 s+ g4 t' \2 k1 ]! E. R - __HAL_RCC_SYSCFG_CLK_ENABLE();
* v& k3 U9 Z- v8 s - // Remap SRAM at 0x00000000
复制代码- __HAL_SYSCFG_REMAPMEMORY_SRAM();
6 z6 `0 J" m) X# W. p& \. R$ ?% \+ N& R3 r5 |6 {6 t# u
在Keil下设置IROM1:start 0x8003000 IRAM1:Start 0x200000C0: V0 o' c8 x( Q
( d3 N6 Y4 r, `7 r9 H
stm32f0 没有中断偏移寄存器,所以将中断向量表读取到RAM中,然后重映射到RAM地址.
1 w/ f) G6 X! X% Q8 Y
! p$ V! l2 _: c
' P- h* N) k3 {; Z7 x |
