【经验分享】STM32驱动SPI接口EEPROM,AT25010、AT25020、AT25040
STMCU小助手 发布时间:2022-4-23 16:44
一、源代码9 B$ h; S# f, n7 H4 B* U
9 E7 [  {& C( @7 ^% }
  1. void eeprom_init()
    ' g% b$ Z/ x: ^7 U7 R  w- d
  2. {
    2 H1 f8 O0 i  ~& z6 m9 ~* J
  3.         GPIO_InitTypeDef GPIO_InitStructure;
    7 V3 U0 X9 y* k8 I5 {% [+ z
  4.          SPI_InitTypeDef  SPI_InitStructure;
    8 E2 l; R* ~5 l) T9 @" f
  5.         RCC_APB2PeriphClockCmd(        RCC_APB2Periph_GPIOB, ENABLE );//PORTB时钟使能 6 R4 m4 r9 W2 c7 t
  6. / G% D- `) q4 \+ K
  7.         GPIO_InitStructure.GPIO_Pin = GPIO_Pin_11|GPIO_Pin_12;  // PB12 推挽
    ! W2 A+ m; U9 q) X' e
  8.         GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;  //推挽输出$ ~: l8 g& F  U6 ?7 O7 }( C5 o' g/ `
  9.         GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;0 c- I3 e4 V7 h8 Z. R6 K
  10.         GPIO_Init(GPIOB, &GPIO_InitStructure);6 Z8 X% F0 h" G! _4 @8 Q
  11.         GPIO_SetBits(GPIOB,GPIO_Pin_11|GPIO_Pin_12);8 c: u; R" Z1 b3 Y" A
  12. # ^$ }3 Q# O2 p$ C1 O1 x
  13. 2 q) c  w7 ?" Z4 R
  14. 9 Z2 z8 R5 A5 B2 `- }
  15.         RCC_APB2PeriphClockCmd(        RCC_APB2Periph_GPIOB, ENABLE );//PORTB时钟使能 0 l- N+ b& O6 x
  16.         RCC_APB1PeriphClockCmd(        RCC_APB1Periph_SPI2,  ENABLE );//SPI2时钟使能         6 |; w$ O3 W+ L) G% ]8 d
  17. ' o, H! m, F8 _* d" @
  18.         GPIO_InitStructure.GPIO_Pin = GPIO_Pin_13 | GPIO_Pin_14 | GPIO_Pin_15;
    . l2 Q% y4 M" U1 U. r! f
  19.         GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;  //PB13/14/15复用推挽输出
    $ _6 p: g  _0 r- \2 }, }! K
  20.         GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;1 w" N( p- S$ ^3 u. |
  21.         GPIO_Init(GPIOB, &GPIO_InitStructure);//初始化GPIOB
    % V: d/ |8 C& N' s
  22. 3 c/ ?/ `2 Z6 A! U5 d- H  g9 @
  23.          GPIO_SetBits(GPIOB,GPIO_Pin_13|GPIO_Pin_14|GPIO_Pin_15);  //PB13/14/15上拉
      ~( O. E3 ?# O( O" z
  24. ; r$ e$ [* Z5 S
  25.         SPI_InitStructure.SPI_Direction = SPI_Direction_2Lines_FullDuplex;  //设置SPI单向或者双向的数据模式:SPI设置为双线双向全双工
    ' |- X6 U3 Y2 e% _
  26.         SPI_InitStructure.SPI_Mode = SPI_Mode_Master;                //设置SPI工作模式:设置为主SPI
    7 P* m3 Q- h3 M& ~1 @
  27.         SPI_InitStructure.SPI_DataSize = SPI_DataSize_8b;                //设置SPI的数据大小:SPI发送接收8位帧结构2 h: D% U8 Y' x9 [
  28.         SPI_InitStructure.SPI_CPOL = SPI_CPOL_High;                //串行同步时钟的空闲状态为高电平2 V6 K5 n: `* s3 Y" ?. e0 |* r  L
  29.         SPI_InitStructure.SPI_CPHA = SPI_CPHA_2Edge;        //串行同步时钟的第二个跳变沿(上升或下降)数据被采样
    1 z/ k) A6 ^* H% W7 @4 K
  30.         SPI_InitStructure.SPI_NSS = SPI_NSS_Soft;                //NSS信号由硬件(NSS管脚)还是软件(使用SSI位)管理:内部NSS信号有SSI位控制
    # N& s' @! e6 e
  31.         SPI_InitStructure.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_256;                //定义波特率预分频的值:波特率预分频值为256$ P6 W% W+ L; w; l# S4 h6 a2 K
  32.         SPI_InitStructure.SPI_FirstBit = SPI_FirstBit_MSB;        //指定数据传输从MSB位还是LSB位开始:数据传输从MSB位开始
    - E0 B" e6 _2 [; U
  33.         SPI_InitStructure.SPI_CRCPolynomial = 7;        //CRC值计算的多项式
    : f' s( c, z+ k! e
  34.         SPI_Init(SPI2, &SPI_InitStructure);  //根据SPI_InitStruct中指定的参数初始化外设SPIx寄存器
    + x% J  G9 J% m) ]! k, ?1 w" z
  35. . a4 f# f! i3 t7 d' `$ N
  36.         SPI_Cmd(SPI2, ENABLE); //使能SPI外设
    3 b) |! l4 K: i- V7 j4 y
  37.         6 y/ ~1 n: P7 i* k
  38.         eeprom_read_write_byte(0xff);//启动传输
      W& V1 R, d, k9 Z3 A
  39. }
    8 Q: ?) D3 c! s. ?
  40. //SPI 速度设置函数
    ' K# O  ?$ @3 r6 E; s- j
  41. //SpeedSet:& H" @& E0 }( p" b3 V
  42. //SPI_BaudRatePrescaler_2   2分频   2 A$ e% X" `8 |- t- e( C3 E
  43. //SPI_BaudRatePrescaler_8   8分频   $ b( U0 h2 [3 G4 ^
  44. //SPI_BaudRatePrescaler_16  16分频  # ^9 _) v8 j6 K0 ^& G
  45. //SPI_BaudRatePrescaler_256 256分频 " G! s7 G" a0 ~' \) z, R# N
  46. 9 d6 V8 k- e& I6 u
  47. void eeprom_set_speed(u8 SPI_BaudRatePrescaler)
    - w6 ~0 v$ M! S( ~
  48. {
    2 _$ ~( o9 K$ v5 a
  49.   assert_param(IS_SPI_BAUDRATE_PRESCALER(SPI_BaudRatePrescaler));
    9 u- U; w& g5 C& M
  50.         SPI2->CR1&=0XFFC7;+ Y7 F3 p3 O( T$ q- \! M; S
  51.         SPI2->CR1|=SPI_BaudRatePrescaler;        //设置SPI2速度 8 L: N0 K9 g; _+ `0 Q9 k, M
  52.         SPI_Cmd(SPI2,ENABLE); # ~2 ^! p# f8 Q: t' r9 _4 x, G3 G
  53. ; Q0 b/ I! R5 D9 k" [8 U: P
  54. }
  1. //SPIx 读写一个字节
    - Z( O9 e9 H7 L& B4 r' Z+ `" @
  2. //TxData:要写入的字节4 t6 c+ I  Y8 @5 o8 j' k
  3. //返回值:读取到的字节
      ]% M' i1 Z2 c8 o7 a7 l
  4. u8 eeprom_read_write_byte(u8 TxData)! Z! |* i, i( V/ U
  5. {                " C/ ^: H& F  m! m' S0 K+ B
  6.         u8 retry=0;
    - B2 k4 X; z: g) j. X
  7.         while (SPI_I2S_GetFlagStatus(SPI2, SPI_I2S_FLAG_TXE) == RESET) //检查指定的SPI标志位设置与否:发送缓存空标志位
    ! _5 @0 t! e9 j& z3 x# r7 z
  8.                 {
    8 ?! |$ d0 G- r9 W- M1 {
  9.                 retry++;8 {$ M! Y5 D% H3 t6 N* [, W$ t$ f
  10.                 if(retry>200)return 0;( C8 w! t# u) H6 ~/ m# F
  11.                 }                          8 g$ `- s6 H7 K; B. f
  12.         SPI_I2S_SendData(SPI2, TxData); //通过外设SPIx发送一个数据
    ) B; T4 g, `/ W7 r8 n: g
  13.         retry=0;! B9 [+ g) p: ]; C3 p0 g/ y
  14. 4 _& ]  G  X" Q- {
  15.         while (SPI_I2S_GetFlagStatus(SPI2, SPI_I2S_FLAG_RXNE) == RESET) //检查指定的SPI标志位设置与否:接受缓存非空标志位
    / A8 {) Z' p9 q5 P' L* i4 ]
  16.                 {
      J+ q" i& q2 |& b
  17.                 retry++;
    . I) o# \" C! U$ r, B/ Q$ \
  18.                 if(retry>200)return 0;7 X, w$ ?7 s2 [
  19.                 }
    - i" Q+ |! o$ c4 h6 w2 z
  20.         return SPI_I2S_ReceiveData(SPI2); //返回通过SPIx最近接收的数据                                            + m  {2 X& J3 {$ j1 y, D" f
  21. }
  1. //==============================================================================
    ! M, q$ Z0 I' w- a
  2. // 描述: 在AT25读状态寄存器: d% @4 ?- \: `) Q
  3. // 输入: 无
    1 R% a4 p  a8 j' A; j; k9 A4 p. h% _% Y0 Y
  4. // 返回: unsigned char dat 状态寄存器数据% L- h- m: b: R' F/ P- {3 q" r
  5. //==============================================================================
    " l; L8 n' x: F9 x. M2 E
  6. 6 S( R) y  B! ~" m+ d' f1 t5 C2 r* R
  7. / X3 D, O8 j$ R; `5 c6 F
  8. u8 eeprom_read_sr(void). P# h. H/ U$ K0 W, d' i
  9. {
    ! `( K5 O1 M' O2 K1 N9 v2 Q2 `
  10.         u8 dat;
    & ]6 Z0 \, A3 E0 {
  11.         eeprom_cs=0;
    # Q+ {+ t; _1 x0 j' ?+ i
  12.         eeprom_read_write_byte(RDSR);        //  定入指令0x05! G1 \! M' {7 |2 m3 G
  13.         dat = eeprom_read_write_byte(0xff);       //  读回数据. D+ W" C8 b- Y1 c
  14.         eeprom_cs=1;
    ' h0 g. f9 k* H; l+ m6 g# l
  15.         return  dat;3 W/ J4 |, I7 Y
  16. }  c$ r) x; x9 N" e- P
  17. . D! E+ P% `4 S3 `0 D$ w( @) K
  18. //==============================================================================% n& z9 B. i! p
  19. // 描述: 向AT25写入一个数据/ u, r$ d1 h; u
  20. // 输入: unsigned char Dat 字符数据, x8 ^" j, D8 h. V/ b
  21. //       unsigned int addr 写入的地址
    $ y" A. }$ `  ~. X3 ~0 c! d
  22. // 返回: 无: N! w# a- [  D; L5 n* u; ?% n
  23. //==============================================================================
      }& }: H1 i2 b0 Y& A/ H
  24. void eeprom_write_byte(u16 addr,u8 Dat)
    " I0 T6 I1 v4 v* N1 ^
  25. {
    $ h* k" {0 e  \$ z: Y
  26.         unsigned char Add;
    5 H5 Y" q. ?, ]& B( \
  27.         while(eeprom_read_sr()&RDY);                   // 读状态寄存器, K1 f: f# m9 {: J) @5 G$ {
  28.         + p! r0 d0 Q2 ^2 @
  29.         eeprom_cs=0;' f5 t+ T, n) H9 L/ p4 n. `
  30.         eeprom_read_write_byte(WREN);                           // 写使能锁存8 H* ?4 Z/ Y0 T1 e; x, S' n- L
  31.         eeprom_cs=1;
    % k/ b% O  Z. c( e0 N' s, a
  32.         , t+ U8 u# J5 w# I7 D4 S
  33.         eeprom_cs=0;                                  // 芯片使能 . M; X7 x7 x; Y: ?$ \1 y  o8 f' P% @& o
  34.         // 写入写操作指令
    0 V6 U8 X% Q- z
  35.         if(addr>0x00ff)
    ! l! Q- b7 ^1 n
  36.                 eeprom_read_write_byte((WRITE|0x08));           // 地址大于2554 F7 J* l: D; R* q/ _% T
  37.         else
    7 s, ~# ^! q4 a/ x9 v$ E
  38.                 eeprom_read_write_byte(WRITE);                  // 地址小于2551 A  K$ W, ]: O1 o) e4 [& N
  39. 7 t4 o( s+ @* S5 q. e% h0 S" F
  40.         // 写入地址
    ; f1 S3 ]) b! S( r+ v) H
  41.         Add = (unsigned char)(addr & 0xff);             // 将地址换成8位
    $ K2 b6 L; O; _
  42.         eeprom_read_write_byte(Add);
    2 V7 k# K. X, d* a
  43. * A3 @* M# a  W
  44.         // 写入数据
    9 P8 ~$ s& t- a2 D# C. W% b
  45.         eeprom_read_write_byte(Dat);
    9 v- B% H6 j, Z6 E7 K; \
  46.         eeprom_cs=1;                                // 芯片关闭    . Z! }+ j2 S( R* N
  47. }% \6 ~/ s3 Z+ k, o) q. X5 B) E
  48. //==============================================================================
      u  x: Q' j8 j* L/ u
  49. // 描述: 在AT25读一个字节操作: m- f  M3 ]0 f& A3 N
  50. // 输入: 无
    ! u7 S2 U, z) N6 c; Q7 S
  51. // 返回: unsigned char dat 读出一个字符数据
    & q% }8 l2 ~: B2 O! F
  52. //==============================================================================6 X1 A* q) r0 h, z; Q
  53. u8 eeprom_read_byte(u16 addr)/ \5 y# u7 Z3 z
  54. { : f" n, `2 q% a3 B# i
  55.         u8 dat,add;
    6 n) h! o$ z& q# u1 G
  56.         while(eeprom_read_sr()&RDY);                   // 读状态寄存器  9 T4 v& k6 F2 H8 O( E, v
  57.         eeprom_cs=0;+ m3 e( t* @; v! N( l
  58.         // 写入写操作指令 ' x* M% [- L/ T  h
  59.         if(addr>0x00ff)8 v# I) N4 K% _, @
  60.                 eeprom_read_write_byte((READ | 0x08));         // 地址大于255
    ( i4 f' a  R6 n. f. t! a
  61.         else
    5 ?/ v) T& t3 x9 ]* y$ j" w
  62.                 eeprom_read_write_byte(READ);                  // 地址小于255
    ; p5 ]1 `  S% @2 _  N1 O5 E7 f
  63. 4 f  o! M2 y3 T$ K2 w; ?4 Y
  64.         // 写入地址. u2 B! e- f0 f5 w
  65.         add = (unsigned char)(addr & 0xff);             // 将地址换成8位6 C( W; D6 }6 j/ w, h
  66.         eeprom_read_write_byte(add);
    8 f! I& W) X7 [4 [9 j0 s
  67. ) t6 N; X7 H/ M: c: p
  68.         // 读出一个数据/ \- I- y+ g1 E* Q* p
  69.         dat=eeprom_read_write_byte(0xff);
    , d) Q& ]6 C0 g7 t/ r7 _6 Q$ Z2 O
  70.         eeprom_cs=1;* c- |4 ?$ P- V" x3 \' \
  71.         return dat;. ^: q+ q" l! s: z3 o+ w
  72. }; ?& J1 t4 K4 d5 Y9 [
  73. //==============================================================================3 k& t$ I3 T9 W0 q  U
  74. // 描述: 向AT25连续写入数据1 K# n- m  Q9 @  _- t9 R
  75. // 输入: unsigned char *PC 写入数据指针
    8 f. ?% {1 A& v) p- E
  76. //       unsigned int count 写入数量计数
      \  k. Y. t6 T, k
  77. //       unsigned int SatAddr 写入起始地址# m3 z' a; F8 P( E. z: J
  78. // 返回: 无
    7 J4 S* B4 I" G7 Z; C0 ]
  79. //==============================================================================3 ^0 w+ m8 C* ^8 ^9 R
  80. void eeprom_write_buf(u16 startAddr,u8 *buf,u16 count)7 _+ u0 r( Q8 `0 \, J9 u
  81. { $ j" m4 \6 H/ _: F
  82.         u8 Add;
    7 t% {5 x/ J8 _5 d
  83.         u16 i;0 ^" c  V/ e8 y6 Z
  84.         while(eeprom_read_sr()&RDY);                   // 读状态寄存器1 Y9 P% A# ^9 [
  85. 3 \& ?8 l2 v: E2 U6 k
  86.         eeprom_cs=0;6 W8 E: ?' R' @& c; I6 A/ o
  87.         eeprom_read_write_byte(WREN);                           // 写使能锁存
    2 Y  ]) \% U( H/ R# K
  88.         eeprom_cs=1;4 J) z  G& C2 m4 |- ~4 B
  89.         eeprom_cs=0;6 G- @) b/ |7 N( l) b1 h8 ^
  90.         // 写入写操作指令 # y; h! Y6 z6 K7 V
  91.         if(startAddr>0x00ff)
    & l  O( _; F% C" ~
  92.                 eeprom_read_write_byte((WRITE|0x08));           // 地址大于255
    " ^# s% G' y! G" H  i
  93.         else
    ' y$ c& Z* \+ P+ f: I
  94.                 eeprom_read_write_byte(WRITE);                  // 地址小于255
    ' v* a* _/ j$ j0 m3 O
  95. ; P2 p! J) c. m
  96.         // 写入地址
    ' ]) H  N  E3 y  ^/ z( M: I" ?+ o
  97.         Add = (unsigned char)(startAddr & 0xff);             // 将地址换成8位
    ; o; P) J; U: o: K: ]# g# i; L
  98.         eeprom_read_write_byte(Add);
    + O  ]' F5 U) Z. m$ [6 O& k
  99. ; w' ^7 z: d) I( `# g+ V
  100.         for(i=0;i<count;i++)// 写入数据# Y, }+ q6 m# U$ M& w( l7 ^& y
  101.         {
    ! E: a- t: X4 D: `) f3 s- P# R
  102.                 eeprom_read_write_byte(*buf++);2 f2 p, C5 ~* N( [! H
  103.         }+ {1 ]+ u* L+ O1 \
  104.         eeprom_cs=1;                                 // 芯片关闭    # P: W2 M2 O7 F! g; n4 c
  105. }
    0 b6 L" y- H% |7 N+ e
  106. //==============================================================================
    " o- L* m+ F. N& {5 D$ x- p
  107. // 描述: 在AT25连续读数据. Q$ Z4 E$ G% a1 G. n8 I8 |8 K% I
  108. // 输入: unsigned char *PC 读出数据指针
    ! C* a+ [5 E2 S) [& |
  109. //       unsigned int count 读出数量计数
    ' d( m. a' ?9 C
  110. //       unsigned int SatAddr 读出起始地址
      U2 V0 a( Z- O, U: t
  111. // 返回: 无
    2 P& M8 P4 C* R, O1 P# y4 g; x  b+ |
  112. //==============================================================================
    4 l, k; `% X$ Y: Q
  113. void eeprom_read_buf(u16 startAddr,u8 *buf,u16 count)+ T- n; f! ]2 {) j. V/ y5 c' A4 I
  114. {   ^' I2 I, X- F) A) ^1 k4 d
  115.         unsigned char Add;
    + \0 ]0 s7 z( K/ A$ F) v1 v  _1 s
  116.         unsigned int i;
    7 I0 d" P/ R9 t% `# G8 T
  117.         while(eeprom_read_sr()&RDY);                   // 读状态寄存器  1 O% t" `$ L9 j- d# e
  118.         eeprom_cs=0;6 S2 `/ {7 y; p( ?+ u
  119.         // 写入写操作指令 ! Q" D* i+ I; ]% A1 d& @7 F
  120.         if(startAddr>0x00ff)
    6 m. g' {# S6 i% n% ?( i$ t. B: z
  121.                 eeprom_read_write_byte((READ | 0x08));         // 地址大于2556 t6 l2 v6 D8 @* F! D8 a
  122.         else
    % G- V5 Z' t1 i: H
  123.                 eeprom_read_write_byte(READ);                  // 地址小于255! z" ^/ i) l0 P
  124. ! J% v" e! U7 j$ D. E2 y# ^
  125.         // 写入地址
    & w% v3 M2 Z6 K: U( r( O% K4 _
  126.         Add = (unsigned char)(startAddr & 0xff);             // 将地址换成8位
    6 G. k/ ^6 K0 I. P# a
  127.         eeprom_read_write_byte(Add);
    . j7 I9 D) f9 R
  128. 3 }8 |; I5 x- G& e
  129.         // 读出n个数据
    9 i9 I. q' ^8 l0 ^
  130.         for(i=0;i<count;i++)
    0 o! T7 |+ z6 E. s* r# C; [
  131.         {
    , B, o1 m  S0 X$ }
  132.                 *buf++ = eeprom_read_write_byte(0xff);% t: a8 l' ?7 R3 F& M/ z% ~
  133.         }: h4 m8 ?6 h8 i) `4 ]
  134.         eeprom_cs=1;
    / z: L( o* v, P6 s: s  [+ @* V4 ^* O
  135. }
6 g/ q& @: D' C  t/ c6 m二、测试# r7 A7 o) @5 {$ i
7 O( ~- o# O8 ~6 U" H/ z% o" [
  1. int main(void)
    / l9 Z/ n; ?. a/ I9 M( A+ w3 ~6 D
  2. {
    & D" y3 N- B  L; n  {+ C7 c& z
  3.         u8 buf[5]={0x01,0x02,0x03,0x04,0x05},i;
    5 K! b' F* y8 A7 i9 b# C
  4.         uart_init(115200);  b! E% h% I6 C2 R
  5.         delay_init();
    " c, A: M' h5 @% d
  6.         program_led_init();
    9 B8 n1 k8 ^+ z$ L8 P
  7.         9 W' p; {- T1 i
  8.         eeprom_wp=1;
      v4 N4 }/ u1 T) t& U% V7 N. H
  9.         eeprom_init();3 G9 H. y2 U! M5 v5 C( x& U
  10.         eeprom_write_buf(0x0000,buf,sizeof(buf));
    2 Y# {$ c. N( ?  I4 B6 O" c
  11. //        eeprom_write_byte(0x0000,0x08);7 V$ g  P3 F- P1 i0 N; @
  12.         memset(buf,0x00,sizeof(buf));
    3 z+ S& M6 v( X9 Y8 j$ G& x. P
  13.         eeprom_wp=0;
    7 q) G. f+ m! g9 U9 V9 B$ i% u; t' N  N
  14.         while(1)9 f  w6 e7 J( d) J7 Z
  15.         {        2 ?/ t8 r. [4 [# x6 s
  16.                 ( t9 B( f: {% I* {5 V
  17.                 eeprom_read_buf(0x0000,buf,sizeof(buf));
    " a- F2 ^- t) f' R" P, A/ }
  18.         //        buf[0]=eeprom_read_byte(0x0001);3 T. D4 r3 I& z9 v. e8 P3 V4 B4 X
  19.                 for(i=0;i<sizeof(buf);i++)  k  {" Y8 H% H1 z4 B" E' N% @
  20.                         printf("0x%02x ",buf<i>);: j! O7 @% M4 x1 b- K% a% f
  21.                 printf("\r\n");
    + N  u6 k2 n2 {  {0 L/ h
  22.                 memset(buf,0x00,sizeof(buf));+ n, d. `6 W" |/ d2 Y
  23.                 . \  ^- E8 k% |  `
  24.                 program_led_data(0x10,0x10,0x10);
    7 u; p- H0 m4 i2 @- {9 r
  25.                 delay_ms(500);
    , r6 E$ @. Z% t
  26. % m8 D1 V) {# Y4 d' T- k0 w
  27.                 program_led_data(0x00,0x00,0x00);/ M% G1 ?: h+ |# N5 U8 U7 b4 i
  28.                 delay_ms(500);        ' }3 D. g; \6 T% |: `
  29.
    6 W) f# i% k( u! w( k$ y1 h7 K
  30.
    1 U# M" S, t) z2 |
  31.         }
    7 {  Z9 R4 V' L' |% Y. ~3 D+ F/ G# I
  32. }5 d; T% J$ N* I! s) q( ]$ j9 e" \4 @
  33. 4 ^' G! ~4 B9 h  M4 h; [
  34. " g$ b5 `: `3 y0 `( o* A
  35. </i>
, Y4 i& Y$ \0 R& h) O. m5 w
赞 收藏 评论0 发布时间:2022-4-23 16:44
